Solution for lifts/flats
I have a 3rd generation with no sliders or aftermarket bumpers. I have a few questions:
-If I need to change my tire, I have a 265/75/16 as a spare. I am running 285/75/16's. Will I damage anything running this spare for a short time?
-Could I use a Hi-Lift jack without sliders, etc to change a tire? My stock jack will not even come close without a bunch of 4x4 pieces of wood
-Any other ideas, other than not to get a flat tire?
You will most likely notice some serious pull with a spare. You have to do what you have to do though. I would get it taken care of asap. Also you may be able to get by with your hi-lift on your hitch. (don't quote me on that though. Surely someone else will chime in to correct me if I am wrong)
Yeah.. I was afraid of that.... My wife has the clamp on the check book, so the sliders will have to wait. I guess a few pieces of 4x4 wood will have to do with my stock jack :pat:
I am in the beginning stages of coming up with a bracket that will tie in with my rear anchor points to hold my spare inside the rear cargo area. Then I could mount a hi-lift jack along with it.
I will mount the bracket in place of where the stock hooks are. The bracket wil be made from spare parts I had from a SURCO safari roof spare tire mount.
Have it mounted in this area.
If you get a flat on the front, and you have to drive more that 2 miles, take the time to put the spare on the rear, and a rear up front. My dad drove 600 miles back from hunting one year with a 235/75/15 on, when the rest were 30x9./50. Not even as much different as a 265 - 285..and it was a PITA
Hi-lift makes a bumper tool, but I am not sure if stock bumpers are strong enough..
I would NOT use a hilift on stock anything. Period, end of story.
I would NOT use a hilift on a trailer hitch - waaaaay to easy for the truck to shift laterally (even if it's blocked), and that is some scary sh|t. I'm speaking from experience on this one.
Running an unmatched tire on the front will cause the truck to pull/wander. How much will depends on how much difference there is between the tires. Putting it on the back is generally safer, assuming you can run your rear diff open.
To change the tire, use the stock jack on the lower control arm. There are jacking points other than the frame rails that can be used in a pinch.
The stock jack will work fine for much more than 285/75/16.
The front stock jack location point should be under the lower control arm as mentioned above. This lifts the tire without having to extend the suspension to do so. This is much safer as you only need to lift the vehicle a few inches.
The rear stock jack location is under the rear axle. It isn't intuitive since there is no flat location on the axle tube to put the jack. I think Toyota should have added this. But it is still safe and is even recommended in your owners manual. This has the same advantages as the front. You only have to lift the vehicle a few inches and don't have to decompress the suspension before the tire lifts off the ground.
Cool... I thought it would be a bigger issue using a stock jack with 285's and a lift comprising of OME 2.5 inch and 2 inch BL. But I haven't tried the stock jack yet to see how it matches up to the lift --- as a precaution.
Originally Posted by ROOFGOOF
I have factory rear locker. I guess I could just find a crap used 285/75/16 and put it on a spare rim just in case.
10-4... I am slowly learning, I appreciate the help.
Hopefully I will be able to get some type of tire mount in my cargo area along with a few other little goodies that will make a nice and clean install. The spare takes up room, but I don't think its too crazy having it back there. Did I mention how much I hate the spare hangin undernieth the truck
When jacking up my IFS I put the jack right inside of the lower ball joint on the knub that faces down. It makes a good point to jack from. Some tire/rim combos might not allow this point to be used though.
that said, i just load my spare in the trunk when goin out wheelin or a long distance drive. every little bit helps weight wise for mileage so going spare free helps there too. i used to strap my spare vertically, holding it down with ratcheting straps. but when wheelin and bouncin around alot, it would just flop over. nowi just leave it flat on the trunk floor, and mount whatever i need to on top & tie it all down with straps...most of the time im still able to utilize the cargo cover too...
