Snorkel Craze: use em or loose em?
Old Apr 7, 2006 | 02:23 AM
Turd Ferguson's Avatar
Originally Posted by 1985 4Runner
Don't have one. But now I wonder exactly how to go about putting one on a carbed V-8. I think they definitely serve a valuable function.
Some sort of ram-air system, maybe a large center hood scoop into a sealed intake line? Or if you're using a Rocket V8-style (olds 305 comes to mind) filter and intake, you can attach the snorkel tube to the intake tube. On my Cutlass we routed PVC heat-bended to that tube from below the bumper to give it a type of cold-air intake. Some flex tubing could go a long way.
Old Apr 7, 2006 | 08:39 AM
AK95Taco's Avatar
I put an internal one in the day after I got back form THIS I missed the line by literally 3ft and came about 1 second away form hydrolocking the motor. This was the 7th or 8th of about 15 water crossing that trip and every other one wasn't above the headlights...
As for the noise and such, I just do the deckplate and rag thing. Honestly it isn't that much louder than just the deckplate (at least with the magnaflow).
Old Apr 7, 2006 | 09:08 PM
Hey, here's one- those of you that made your own, where did you get the intake piece that looks like a safari snorkel? I did a google search but couldn't come up with anything.
4Hummer, I'm looking at you!
Old Apr 7, 2006 | 09:23 PM
4x4Lamm's Avatar
4x4connection.com, Turd.
Lamm
Old Apr 7, 2006 | 09:59 PM
  #25
sschaefer3's Avatar
No Snorkel, Original Motor.
http://www.sonoransteel.com/Rubicon_Trail_002.jpg
Old Apr 7, 2006 | 10:04 PM
  #26
4x4Lamm's Avatar
What if you had run into a depression under that murky water Steve?
Or, if you are like most of us, and had less lift and smaller tires?
Lamm
Old Apr 7, 2006 | 10:12 PM
  #27
INsr5runner's Avatar
I gots one. Haven't had to use it for a while though. I've kinda been out of four wheeling.
I think I was like the 2nd or 3rd 3rd gen to do this back in the day! heh,heh
Old Apr 7, 2006 | 10:18 PM
  #28
sschaefer3's Avatar
Lamm
Well we sent Stubbs through first. Never go into water you don't know what is under it and I do have big tires and 5" of lift. If I had less, I would have looked for a bypass.
Old Apr 8, 2006 | 08:51 AM
  #29
Lamm
You da man! :thumbup:
Old Apr 8, 2006 | 09:20 AM
  #30
spindleshanks's Avatar
Many people argue that instead of decreasing ingested trail dust, they actually increase your particulate intake.
Old Apr 8, 2006 | 09:38 AM
  #31
WATRD's Avatar
Not even a contest for me.
Before the snorkel, a normal weekend of summer wheeling included an air filter cleaning at the end if I wanted any performance on the way to work Monday.
After the snorkel, my filter is still mostly black and fresh at the end of the same weekend.
Not just a noticable decrease in particulate intake, but a HUGE difference.
I have heard the same from several others I wheel with.
Old Apr 8, 2006 | 09:43 AM
  #32
BruceTS's Avatar
With the system I have in my rig, it reduces the intake of dust.
Old Apr 9, 2006 | 11:31 PM
  #33
DrBeau's Avatar
If you think about it logically, while you can see a lot of dust go into the air, there is much more as you get lower to the ground. This is because even though the lighter material gets higher, it can also be low to the ground. The heavier material can't get as high. This means you have more paticulate matter as you get lower to the ground (as there is both light and heavy material).
Old Apr 9, 2006 | 11:42 PM
  #34
Tofer's Avatar
Sponsor
this is making me want a snorkel more and more...
Old Apr 11, 2006 | 12:27 AM
  #35
Blizzard's Avatar
If you can manage to get an Airflow hat it will be cheaper.
Here the Safari hat is near 120$ and the Airflow like 60$...
Since I've my snorkel my filter don't gets so dirty (K&N) and eliminating the intake resonator has been the best performance increase in my truck, a 3.0 Turbo Diesel sucks a lot of air, if it flows nice it revs a lot better.
David
Old Apr 11, 2006 | 11:23 AM
  #36
tc's Avatar
tc
Reminds me of that line from Indiana Jones:
"Oooh - asps - very dangerous. You go first."
Old Apr 15, 2006 | 10:17 PM
  #37
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
does having a snorkel not increase the small water intake from heavy rain and such? in heavy rain the stock intake is sheltered by the fender, but cant the snorkel catch some of that and suck it in? i geuss its a negligible amount though...
Old Apr 15, 2006 | 10:21 PM
  #38
4x4Lamm's Avatar
According to ARB the intake head filters out water with air preassure.
Lamm
Old Apr 16, 2006 | 03:23 AM
  #39
Fred Anarat's Avatar
Gentlemen, Let me tell you a story,,,,
Bear with me here.
Up here in the GWN (that's Great White North) when it does thaw, many of our trails require water crossings. I would often have to cross this tiny little creek - 10 ft. across and 1.5 ft. deep, never a poblem....Untill.
After a week of rain and some time for the water levels to drop, I decided to head out across that same creek and up my fav. trail. Unfortunately I didn't realize the rain had caused the banks to erode and made the channel alot deeper. When I dropped in, the water rolled up the hood to the base of the windshield of my '86 Toy P/U. I paniced and stomped the throttle but, in doing so caused the motor to suck up a big gulp of water and engine stalled out.
Before it died the truck managed to crawl up the far bank enough that the engine and cab were out of the water but the rest of the driveline was under water. I Hiked out, got a pull, towed it home and started to change out all the oils and re-grease everything. That was when I realized I had hydraliced the motor (filled the cylinders with water). Pulled the sparkplugs, changed the oil/filter, cranked the engine over a few times to get the water out. Put the truck up on blocks, fresh oils in the driveline new oil/filter for the engine, replace the plugs start the engine and run it in gear (4 wheel) for a min. Drainied all the oils again, I then used oil safe waterdisplacer (idustrial WD40 from CAT) and ran it in gear again for a min. Drain and relace the oil/filter and run it in gear again, and repeat. I probably changed the oils another 8 times in the next 1000 kms,,,,but to no avail.
After about 3000kms the #4 piston rod went with a bang, literally, and you could reach through the block from one side to the other the holes were so big. The #3 and #2 rods were also bent from being hydraliced. At 4500 Kms I had to replace the rear U-joints, 5000 kms and the rear end went and at 7000 kms I sold it before the transfercase exploded.
Moral of the story, All of this could have been avoided If I had only had a snorkle :pat: (that includes all the breathers on the diffs and tranny/transfercase)
Old Apr 18, 2006 | 02:29 AM
  #40
Blizzard's Avatar
Two friends of mine have hydrolocked their V6 4Runners in the past month...
V6 2nd Gens have the intake lower than the diesel ones...
David
