slider install ?'s
Old Oct 2, 2005 | 06:35 PM
6lug's Avatar
slider install ?'s
ok fellas (and ladies),
i tried searching for the answer to this question, and im sorry if i missed it, but any help will be appreciated....i just got in my MC sliders for my 4runner. When i mocked up the install, i ran into a prob that surely someone else has...i dont have a body lift, dont really want one, and dont have the money for one even if i did want one, and here's the prob...the sliders are connected to the frame by three pieces of tubing right? well without a body lift, the tubes go below the frame rails. even putting them up as high as they can, they hit the pinch weld, and stick below the rails. but, could i notch the pinch weld in the three tube locations and then attach them...that would give me enough space...what do you guys think....
Old Oct 2, 2005 | 06:37 PM
r0cky's Avatar
is there any possible way to get a picture of what you're describing so we can visualize better? if not, i'm sure someone else can still offer some good advice! bump!
Old Oct 2, 2005 | 06:40 PM
Localmotion's Avatar
a pic would be the best way to help...but i say why not just hammer in the pinch weld?
Old Oct 2, 2005 | 06:46 PM
6lug's Avatar
also sorry to ask, whats a bump? and i dont have the sliders with me at school...im in college three hours from my home, so i cant do it yet.... but ill try to describe it better....ok imagine looking directly at the side of the vehicle (its a 2nd gen)...it has no body lift, and the frame rails arent that visible below the body...the body has a pinch weld under the doors...if i put the slider leg tubing perpendicular to the frame rails (the way they should be attached) the top of the tubing hits the pinch weld under the doors, but the bottom of the tubing that should attach to the frame hangs a little bit below the frame....thus the prob....should i just notch the pinch weld to move up the tubing legs, or is that a bad idea?
I cant do the pics right now sorry
Old Oct 2, 2005 | 06:58 PM
sorry i cant help ya. A bump is something you say when you want other people to look at it. It brings the thread to the top of the list, it also acts as post padding..LOL
Old Oct 2, 2005 | 07:00 PM
4Crawler's Avatar
I had to notch the pinch weld on my old Americal Metal sliders. May as well do that because the slider mounting tubes are going to make dents in the pinch weld on their own, unless there is an inner bar running the length of the pinch weld. Or weld some mounting plates to the mounting tubes, sticking up above the tubing and then weld that to the frame (and let the tubes hang down below the frame far enough to clear the pinch weld.
The other option would be to bevel the mount tubes to allow them to angle downwards enough to clear the pinch weld. I have to do this on my 1st gen pickup sliders:
Old Oct 2, 2005 | 07:14 PM
6lug's Avatar
thanks guys...anything else? anyone else? not that i dont trust you 4crawler, just checkin everyone else or see what others did....
Old Oct 2, 2005 | 07:19 PM
4Crawler's Avatar
Or call up the shop or post on their web forum and ask them directly. I imagine they have had one of their sliders installed before:
Customer Service and Product Support
Old Oct 2, 2005 | 07:26 PM
6lug's Avatar
duh...good thinkin
Old Oct 3, 2005 | 07:46 AM
00Runner's Avatar
I remember someone here notching their pinch weld to fit sliders. But you need more space than just barely making them fit because the body flexes as do the sliders when the entire weight of the truck is on them. If you think that you every might want a body lift I would do it now as it will make mounting the sliders a lot easier. Otherwise I think that Rogers idea of angling the mounting tubes down away from the pinch weld is a very good idea and would be easy to do with round sliders like you have.
94ofCanada
Aug 14, 2015 06:37 AM
nickbeauregard
12
Aug 7, 2015 06:04 AM
priest16
15
Aug 6, 2015 07:43 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
coryc85
Jul 6, 2015 04:07 AM
