Replacing coil springs, need some help
Old Dec 7, 2005 | 09:27 AM
jethro's Avatar
I'm looking to raise the new 4runner a bit, and was looking at the OME/Tunda setup, but I really don't need that much lift.
My next (original) plan is to just replace the 2WD springs I have now, with some 4WD springs.
My main concern in doing this is the shocks. There's no need to replace them as of yet, I think they're fine. I'm just starting to hate how low the 2WD 4runner sits.
So my question is, which 4WD springs should I get? I searched and searched for an answer because I know it's out there, but came out with nothing. I think I remember reading that the '99 4WD springs are a little taller, I could be wrong though.
So which coil springs would you choose, keeping in mind I want to keep OEM 2WD shocks.
Old Dec 7, 2005 | 10:52 AM
X-AWDriver's Avatar
Just get the '99 coils and yes,they are an inch taller and they won't kill your wallet.
Old Dec 7, 2005 | 11:02 AM
jethro's Avatar
Thanks man, was I correct in thinking these are a little taller than other years? And will my stock 2WD shocks be compatible with these?
And also, I've been searching for a while, and I can't find a place that sells the springs. :cry: I know they're out there.
Any recommendations on where to buy these from?
Old Dec 7, 2005 | 12:56 PM
jethro's Avatar
That's what I was thinking. But turns out to be $248 for a new set of springs. :cry:
I might as well save up for a real lift.
Old Dec 7, 2005 | 01:34 PM
Jared's Avatar
That seems a bit high to me. You can find brand new coils with lift for that amount.
I bet with some searching you can find some used ones in good condition that are much cheaper than that.
Old Dec 7, 2005 | 01:45 PM
Jared's Avatar
Here is someone selling the rear coils in the classifieds section for $50.
I don't know if they are still available, but worth a try.
Old Dec 7, 2005 | 03:59 PM
grimpy's Avatar
The 99 4wd has the extra coils... I heard that some 00's have it also... However, my 00 is an early build and did not have the longer coils... Best bet is to stick with the 99's. Fink should have his 99 4wd rear coils for sale...
Old Dec 7, 2005 | 07:05 PM
ebelen1's Avatar
If you're only changing the rear springs, it's fine to keep your stock shocks. However, if you're changing your springs up front as well, I think you need to get new shocks as the 2WD shocks are shorter. Up front, you have a coilover system and having a taller spring with a shorter shock may cause issues. As I'm not an expert on this, I don't know if I'm 100% factual.
Old Dec 7, 2005 | 07:32 PM
ASU4runner's Avatar
http://www.toyota-parts-dealer.com/parts.htm
They're about $150-160 w/ shipping included there.
smthwsn357
May 1, 2024 07:28 AM
sandyota
Feb 4, 2021 11:16 AM
Sleaker
Aug 26, 2020 06:03 AM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
