Removing sleeve in shock
Old May 7, 2005 | 07:31 PM
Praufet's Avatar
The shocks I ordered for the rear have a metal sleeve in the bottom part. If I can remove the sleeve it will fit right over the rear mount. Is there an easy way to remove this sleeve or will I have to cut/grind it out?
Old May 7, 2005 | 07:47 PM
deathrunner's Avatar
I jost found a bolt of the same diameter and just tapped it through. SHouldn't be too bad.
Or if you can get some needle noses on it, try yanking it that way.
Old May 8, 2005 | 01:44 PM
Praufet's Avatar
Tried all of the above and its not budging. I tried cutting it out, but I don't have anything that can get in there. This a rancho shock with poly bushings.
Old May 8, 2005 | 01:53 PM
KevyWevy's Avatar
the bushing most likely wont fit anyways. i had this problem on my 4Runner. i ended up drilling out the bushings and buying new ones. the guy at the 4x4 shope where i bought my new bushings said that they cheat and burn them out.
Old May 8, 2005 | 02:01 PM
Praufet's Avatar
how much did the bushings cost?
Old May 8, 2005 | 03:03 PM
KevyWevy's Avatar
they should only cost like 5 or 6 bucks
Old May 8, 2005 | 04:20 PM
2WICE's Avatar
Guest
From: Las Vegas.. Soon to be heading for south america in the 4R
off topic, but where can i get an entire set of poly bushing? minus shocks if possible
Old May 8, 2005 | 04:53 PM
KevyWevy's Avatar
what kind of poly bushings? just shock bushings? im lost
Old May 8, 2005 | 04:58 PM
mt_goat's Avatar
You can make a little press out of a vice. Put a large socket on one side big enough for the sleeve to go into, on the other side put a socket small enough that the sleeve won't go into it. Then start cranking the vice shut until the sleeve is pushed out. Watch out or you may end up with the small socket stuck in the bushing.
Old May 8, 2005 | 05:01 PM
4Crawler's Avatar
Originally Posted by 2WICE
off topic, but where can i get an entire set of poly bushing? minues shocks if possible
Probably depends on the shocks, but for Ranchos, you can buy a poly bushing kit at most places that sell the shocks:
http://store.summitracing.com/defaul...h.asp&N=400211
Old May 8, 2005 | 05:33 PM
Robinhood150's Avatar
I just went through this with my 5009s. I ended up threading a hacksaw blade into the sleeve and cutting it out.
Old May 8, 2005 | 07:37 PM
Praufet's Avatar
Did it come out pretty easy once cut? Did you cut it on both sides or just one?
Old May 8, 2005 | 08:09 PM
2WICE's Avatar
Guest
iv already got the poly bushings that came with the OME shocks... i wanted to do the other bushings cuz after getting up close with them today i was not happy
Old May 9, 2005 | 12:12 PM
You'll notice the sleeve is just a rolled pin so it already has 1 slice in it. Use the hacksaw to cut another slice in it about 90 degrees apart and you should be able to get that small chunk out of it. Then bend up the rest of it and pull it out. But, no, you've still got to wrestle it out with a vise grip.
Old May 9, 2005 | 02:30 PM
Praufet's Avatar
I use a pitman puller and a socket extension to get them out, worked like a charm. Got them both out in a few minutes, almost done with the rear, then to the front.
Old May 9, 2005 | 07:36 PM
Marc P's Avatar
I got some free Rancho F150 takeoffs from my work, and the only way I got them out was to destroy the bushing. Other shocks have sleeves that are pretty easy to remove, but not Ranchos!!
Blamalam
Mar 12, 2022 07:34 AM
nvdesertrunner
May 11, 2020 08:18 PM
okamikai
Apr 30, 2018 10:19 PM
trailgoat
Aug 13, 2015 05:54 PM
andrewtexas123
Jul 23, 2015 11:22 AM
