downey springs flex
Old May 9, 2005 | 04:43 PM
fatdudesurfin's Avatar
downey springs flex
do the downey lift leafs for a 92 pickup 4wd increase wheel travel? if they do, how much?
anyone got pics of the downeys?
i mean the 3" lift leafs btw
Old May 9, 2005 | 04:46 PM
AxleIke's Avatar
I have the 3 inch springs on my Runner, and they increased wheel travel by about 5-6 inches, but i had add-a-leafs on there before, and they really limited the travel. I like them a lot.
Old May 9, 2005 | 05:56 PM
i see you're running those with the shackles, and im not sure exacly what the shackles do in your application
do your 1.5" shackles assist the lift? articulation?
thanks for the input by the way
Old May 9, 2005 | 07:11 PM
jimbo74's Avatar
extended shackles due increase articulation as they allow the springs to compress or droop more as compared with stock shackles
Old May 9, 2005 | 09:08 PM
awesome, thanks for the info
so shackles do increase articulation (good thing), but do they effect the lift at all? i'm planning on a 1.5" bj spacer lift up front, and dont want too much of a lift in the rear
Old May 9, 2005 | 09:18 PM
4Crawler's Avatar
Yes, shackles increase lift:
http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ4
to the tune of approx. 1/2" per extra inch of shackle length.
And yes, shackles can increase articulation (springs and shocks permitting) to the tune of 1" for each additional inch of shackle length.
That is if you run a 2" longer than stock shackle, you get 1" of lift and, if the springs allow it, you can compress the springs back to the bumpstop which is now 1" farther away, so you get 2" of extra up-down travel.
Old May 9, 2005 | 11:13 PM
deathrunner's Avatar
Downey 3" leaf pack and prerunner add a leaf instead of the overload
Old May 10, 2005 | 12:38 PM
here's the setup i'm thinking about running
1.5" spacers up front
downey 3" rear lift leafs w/ marlin shackles 1" over stock
would this look funky? front only getting 1.5" while rear gets about 3-1/2"?
how would this compare to a downey 2" lift leafs w/ downey 2-1/2" over stock shackles setup?
one last thing, besides downey and marlin shackles, what other places should i look?
vikinghug
Jun 14, 2016 08:10 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
