recommendations for tie-rods and custom drag link purchase?
Old Jan 26, 2009 | 12:34 PM
McBrat's Avatar
Hey,
anyone have any recommendations for where to purchase a tie rod and custom length drag link, both threaded for heims?
thanks,
Mick
Old Jan 26, 2009 | 03:20 PM
4rnr's Avatar
solid axle? buy the stock in DOM and have a machine shop thread it. Maybe one of the hysteer guys will sell you them (marlin, allpro, etc...)
I know FROR sells them custom as well (for their diamond housings)
Old Jan 27, 2009 | 05:54 AM
McBrat's Avatar
sorry, I thought I had put the info in...
yeah, '85 front axle. coils and links.
I've got a bunch of links to sites I've found, just wondering if there are some that are better thabn others, or if there are huge price differences, etc...
Old Jan 27, 2009 | 06:58 AM
WFO's Avatar
WFO
Ive got the Trail Gear Hy-steer kit on mine. The Rod ends do not have grease fittings which I dont like but they did send me all new ones when one wore out after 10 months. It went bad due to a death wobble problem. Cant really say it was a bad part. But A+ for customer service.
Oh and the arms are not billet.
Old Feb 5, 2009 | 11:33 AM
Volcom's Avatar
I just ordered some Midwest Control 3/4" heims from Ballistic Fab. I am going to make a new tie rod out of 1.5" 1/4" wall DOM and use tubing inserts for the heims. I will have to take off the steering arms and drill out the tapered hole (originally for the FJ80 TRE) to fit a 3/4" bolt.
My current setup are FJ80 TRE's and 1.25" 1/4" wall DOM and hydro assist. I bent up the tie rod and broke my hydro ram. I couldn't ever get the TRE's to stop moving around with the hydro assist. I personally like heims over TRE's. Easier to work with and you don't need a pickle fork to remove the heims from the steering arms to make toe adjustments.
Old Feb 5, 2009 | 11:58 AM
4rnr's Avatar
While that is a fine way to go. Most people do not like heims on the street. They seem to be sloppy as time goes on. As long as you arent breaking them I would run "1 ton fj80 TRE's"
Old Feb 5, 2009 | 02:46 PM
tc's Avatar
tc
x2 for some tube with weld in adapters and then wahtever kind of heim/rodend you want
Old Feb 6, 2009 | 05:08 AM
McBrat's Avatar
thanks. I ended up going with a heavy duty Tie Rod, and FJ80 TREs, and a FJ80 TRE for the pitman arm end of the draglink, and a heim for the axle end...
still waiting on my wheels to come in so I can get the tires mounted and we can figure out the bump stop settings, and see how much clearancing is needed for the steering...
Old Feb 6, 2009 | 07:31 AM
Volcom's Avatar
I agree, the TRE's are better on the street. My little brother has been running heims on his YJ for 5 years now (although not a DD) and hasn't had any issues with them. I hope to get 5 years out of my new steering setup.
94ofCanada
Aug 14, 2015 06:37 AM
priest16
15
Aug 6, 2015 07:43 AM
Poppie51
Aug 2, 2015 11:29 PM
TJWilly
Jul 31, 2015 02:05 PM
kirkrunner
Jul 27, 2015 07:59 PM
