Rear discs
Old Dec 18, 2005 | 06:58 PM
Napoleon047's Avatar
when installing rear discs, yeah, you should replace the bearings anyway, but im talking if you wheel your rig and should break an axle. you would literally have to carry another axle with a rotor already on it and set up.
granted, you could just carry a complete axle with drum brake setup, but then you would have to bleed the brakes after changing the axle, and you would probably have some brake steer in the rear end with one disc and one drum
Old Dec 19, 2005 | 01:09 PM
Praufet's Avatar
Why is it so much easier with gm rotors?
Old Dec 19, 2005 | 02:48 PM
previous post in this thread:
Originally Posted by Napoleon047
that bigrocks kit means its still a PITA to change a rear axle.
with the GM based kits, all you have to do is remove the caliper, pull the rotor off, undo 4 nuts and remove the axle shaft/bearing assembly. put in new axle shaft and bearing assembly, replace the rotor, bolt caliper back on.
with the bigrocks kit, you have to remove the caliper, undo 4 nuts to remove the caliper bracket, remove 4 nuts to remove axle shaft and bearing assembly, press off the bearing assembly, press out wheel studs to remove the rotor, put rotor on new axle shaft, press in the wheel studs, press on the bearing assembly, put in new axle shaft and bearing, replace 4 nuts to hold bearing in place, put on bracket, replace 4 nuts, bolt on caliper.
besides, a GM based brake setup can be done for much cheaper.
Old Dec 19, 2005 | 03:37 PM
waskillywabbit's Avatar
don't forget the initial PITA of getting the OEM rear drum crap gone...that took the longest, the rest of the rear disc conversion was cake.
Old Dec 19, 2005 | 04:47 PM
  #25
Praufet's Avatar
sorry, wasn't clear. What I meant was why do you have to do all that extra stuff with the big rocks kit.
Old Dec 19, 2005 | 04:52 PM
  #26
934rnr's Avatar
The big rocks kit basically mount the rotor to the inside of the axle and you have to pound the wheel studs through the rotor and the axle plate.
The GM rotor has to be machined (which is already done for the kit) to fit the outside inner flange then it can be slipped over the outside of the axle plate
Old Dec 19, 2005 | 05:24 PM
  #27
SEAN_at_TLT's Avatar
People use the GM calipers because they have an integrated parking brake and they are cheap and readily available. If you went to Toyota front calipers on the rear you'd need an xfer mounted brake. If you wanted to keep an e-brake that is. If you are installing discs in the rear might as well go floater for all the other benefits that comme with that. In fact the benefits of the floater outweigh the benefits of rear discs. The rear drums are up to the task but the rear semi-floating axles aren't for serious abuse.
Old Dec 20, 2005 | 06:35 AM
  #28
Praufet's Avatar
just wish the full floater conversion wasn't so much $$$. Any one know what all is included in the kit?
Sep 4, 2015 09:27 AM
kirkrunner
Jul 27, 2015 07:59 PM
SMOD
Jul 27, 2015 01:45 PM
Iceman4193
Jul 15, 2015 04:48 PM
icentropy
Jul 14, 2015 10:23 AM
