rear coil to leaf conversion question
Old May 8, 2005 | 02:19 AM
91 4Runner's Avatar
Just toying around with the idea... What's all involved in converting the rear coils to leaf and a spring over? (leaf springs, shackles, hangers and new perches obviously) but what else? (ie. brake lines and such) Thanks for any info.....
Old May 8, 2005 | 08:20 AM
4Crawler's Avatar
This should explain the whole process...
http://www.off-road.com/toyota/tech/56leaf/index.html
Old May 8, 2005 | 10:44 AM
91 4Runner's Avatar
Thanks 4Crawler
Now the only question I can think of right now is with the shackle mounting, is it just a hole drilled through the frame, or is there some sort of bushing in there?
Old May 8, 2005 | 10:47 AM
4Crawler's Avatar
There is typically a shackle hanger welded beneath the frame for the rear, as shown on the page I posted a link to:
And there is typically a bushing inside the shackle hanger, unless you run something like a Johnny Joint hanger.
Old May 8, 2005 | 09:24 PM
91 4Runner's Avatar
Sorry didn't happen to see the hanger.... Thanks.... Jonny Joint? Could you explain?
Old May 8, 2005 | 09:28 PM
4Crawler's Avatar
A spherical bearing type joint:
http://www.google.com/search?q=Johnny+Joint
AllPRo Offorad sells one set up for use as a shackle hanger.
sandyota
Feb 4, 2021 11:16 AM
87turboPA
Jul 12, 2015 07:49 AM
87turboPA
Jul 9, 2015 05:58 AM
Nickdigg
Jul 7, 2015 06:04 AM
Vargntucson
Jul 4, 2015 12:15 PM
