Question about winch and winch rope...
Old Jan 5, 2007 | 08:27 AM
HaveBlue's Avatar
Hey all,
I'm looking at a Warn M8000 to mount to my TJM T-17. It comes with 100' of 5/16' wire rope. I'd like to replace the rope with synthetic, but I'd like to add 25'. Will I run into any problems if I do that?
The reason I'd like to add 25' is so that if needed, I can use two snatch blocks and effectively triple the capacity of my winch (read: block and tackle). Could I even run 150'?
Any help/suggestions/advice is always grealy appreciated.
Thank you!
Old Jan 5, 2007 | 08:37 AM
Corey's Avatar
Co-Founder/Administrator
You can get a custom made up 25' line or whatever you want with ends on it to mate up to the stock rope you put on there.
I would suggest you get a closed/hasp hook like I use, no chance of an extra line slipping off that way then.
I have the hook like seen here that is yellow.
http://www.masterpull.com/
Just use the extra line when you need it, keep it coiled up in a bag.
Old Jan 5, 2007 | 08:43 AM
terryjmatthew's Avatar
I have 125' of 5/16 synthetic on my XD9000 and have not had any problems. I also have the same hook as Corey. I bought mine from Winchline.com off of fleabay..
Old Jan 5, 2007 | 09:40 AM
Flygtenstein's Avatar
I would put 75' of 3/8's on the winch and carry another 75 in the truck.
Unless you are always pulling at extreme distance with snatch blocks, you will not be getting full strength pulls out of it.
As a rule, going to synthetic will let you run the same amout of the next size rope or about 20-25' of the same size.
Triple blocks? That would be slower the slow.
Old Jan 5, 2007 | 10:05 AM
HaveBlue's Avatar
I meant double blocks :pat:
But I've done a little more web research and discovered a single block is typically enough unless I'm trying to pull my truck out vertically. However, I will probably carry a couple blocks and an extra length of rope since an anchor point isn't always directly infront of the vehicle.
Old Jan 5, 2007 | 10:23 AM
Erich_870's Avatar
What do you do if you come to the connection in your two rope/cable lengths?
The snatch block can't pass a clip so do you have to stop the pull and reset?
Erich
Old Jan 5, 2007 | 05:23 PM
Corey's Avatar
I missed this before, as I was at work in my first response.
http://www.masterpull.com/results.cfm?catid=370
They have the extensions listed.
Master-Pull Synthetic winch line extensions
are necessary when the main winch line doesn't
reach the anchor point required to winch out
a stuck vehicle. An M-P winch line extension is
only a fraction of the weight of a wire cable, and
impressively up to 45% stronger than a wire cable.
M-P winch line extensions are also safer to use
and handle than the wire cable. Due to their light
weight, M-P winch line extensions handle and pack
easily. More advantages include no curls, kinks,
wire splinters or sore fingers.
Old Jan 5, 2007 | 08:28 PM
4x4Lamm's Avatar
I went from 100' to 80' on my M8000. It is cheaper, makes it a lot easier to spool up and gives more power with less payed out. I can't imagine a 125' line crammed onto the drum.
There are lots of trees in Ohio but just in case I have a T-Max 66' winch extension strap.
Lamm
Old Jan 6, 2007 | 06:52 PM
Ric's Avatar
Ric
Banned - User requested
Conversion Chart
heres a conversion chart from Winch Line.
http://www.masterpull.com/results.cfm?catid=959
Im wanting THIS when I do get a new line.
Old Jan 6, 2007 | 08:58 PM
tc's Avatar
tc
Yeah, those safety hooks are the only way to go!
Old Jan 6, 2007 | 09:02 PM
Ric's Avatar
Ric
yea it is, and the syn. rope on top of that, did ya see the price ?
$474
Old Jan 6, 2007 | 09:03 PM
tc's Avatar
tc
That ain't nothing for a pimped up blinged out ride like yours!
Old Jan 6, 2007 | 09:32 PM
Ric's Avatar
Ric
lmao, i almost fell out of my chair, i loved it.
Old Feb 27, 2007 | 06:26 AM
nova's Avatar
found this thread through a search. I use rockstomper.com, they're cheap for synthetic and their ends are quality.
Old Feb 16, 2009 | 05:21 AM
vincentb's Avatar
If you'd like 2 blocks, then you may like 5 blocks too.
If the 5 blocks winching is too compliate, then 2 blocks winching is too.
Old Feb 16, 2009 | 06:29 AM
Dan.3's Avatar
Um seeing that this thread is two years old I think they might have already figured that out by now but that is nice of you to stay on top of it
malteserunner
Early Land Cruisers (Build-Up Section)
89
Feb 9, 2018 06:59 AM
Luvmeye22re
Aug 4, 2015 03:53 PM
makemusic116
Aug 2, 2015 05:23 PM
MTLroadierunner
Jul 20, 2015 03:07 PM
Vargntucson
Jul 4, 2015 12:15 PM
