What problems will i encounter when removing my 2" BL
Old Feb 16, 2009 | 03:19 PM
swapped89's Avatar
I am going to be removing my 2" body lift. I put it on years ago cause i wanted larger tires without havin to cut fenders. Now i have SAS'ed my truck with a TG 5" kit and want to lower the COG a bit. I know i will have to shortin the shifters or just go pull some old stock ones. i dont have bumpers and i remember the steering shaft extension and BL firewall plate. All i can think of is to watch the brake lines, remove radiater drop brackets. And get some shorter bolts. I think thats all the basics.?
Old Feb 16, 2009 | 03:29 PM
waskillywabbit's Avatar
Just don't pinch your fingers.
You can put the lower fan shroud back on but everything else should be straight up.
Now would be a good time to replace your rubber body mounts with some good ES ones.
Sep 4, 2015 09:27 AM
luckypig44
Jul 19, 2015 11:25 AM
kyletbert
Jul 17, 2015 11:39 AM
crashburnoveride
Jul 10, 2015 06:39 AM
ItsJustD
Jul 7, 2015 07:49 AM
