Problems with knuckle rebuild
Old May 17, 2015 | 10:06 AM
keithporter83's Avatar
Ok so I am rebuilding the knuckles on my 83 Toyota truck
I got the knuckles done birfield done and to the point I am putting wheel bearings in got the bearings in and torqued the inner bearing and when the spin the rotor and I get about a 1/4 of a turn and it stops then turns 1/4 of a turn the other way in stops/.
Old May 17, 2015 | 10:10 AM
skypilot's Avatar
First thought, open it back up and look, I bet something is in backwards or is interfering.
Old May 17, 2015 | 10:13 AM
I pulled the rotor back off did not see anything does anyone have a picture of the spindle without the rotor on
Old May 17, 2015 | 10:46 AM
wyoming9's Avatar
Red face
You sure the rotor is not hitting on the dust shield which can happen quite easy .
How does the hub spin without the rotor ??
Get the bearing to tight ??
Old May 17, 2015 | 10:50 AM
Terrys87's Avatar
This video might help
Next video show rebuilding.
Old May 17, 2015 | 11:48 AM
its was the studs that low range I included in the kit that replaced the bolts I reused the bolts and its fine. so far I am very unhappy with the kit I bought from low range it is also missing parts.
Old May 17, 2015 | 01:09 PM
shadowbirdie's Avatar
I bought brake kits from NAPA
I now always inventory the kit before leaving the store, and throw nothing away until driving again
Old May 17, 2015 | 02:27 PM
got it put together and the locking hub does not spin and it says its in the free postion but when I spin the wheel the pinion spins
Old May 18, 2015 | 03:56 PM
any ideas
Old May 18, 2015 | 07:40 PM
Terrys87's Avatar
I hope to rebuild my axle this weekend. It will be my first time and a friend is helping me. I will see what I can find out then.
Old May 18, 2015 | 11:57 PM
wyoming9's Avatar
Red face
Hub put together wrong or the dial just spins and it stays in the locked position.
Old May 19, 2015 | 01:33 PM
I never took the hub apart and it was working before I took it off the truck also I have no idea what to look for as far as how it should be
Old May 19, 2015 | 03:42 PM
who makes the best locking hub replacements that are no crazy expansive
Old May 23, 2015 | 10:38 AM
osv's Avatar
osv
which bolts/studs are you referring to there?
there is no better quality locking hub than what came on the truck... do both sides fail to go into the lock position? doubtful that they are both defective.
Old May 24, 2015 | 05:19 PM
Ok so I got most of the problems solved the pass side is together done and working great the drive side is don't all the way to installing the spindle I totally forgot to order a spindle because the drive side one was toast.
Low range has the cromeoly ones for around 100 but I don't need a cromeoly one nor do I want to spend that mush on a spindle is there anywhere that's sells a stock replacement
bigjstang
Jun 2, 2025 03:56 PM
glowz825
Jan 25, 2022 09:28 AM
msane99
Jul 27, 2015 06:14 PM
Yota.Jay
Jul 23, 2015 08:08 PM
karbin
Jul 5, 2015 11:37 PM
