"powertrax" lockers
Old Dec 1, 2008 | 07:19 PM
JD91T's Avatar
"powertrax" lockers
Hello all wondering if anyone has any input in these lunchbox lockers?
They are very reasonably priced, and all over ebay.
There seems to be a standard and "no-slip", The "no-slip" being about $125.00
more expensive but offering quieter operation.
-Thanks.
Old Dec 1, 2008 | 07:34 PM
tc's Avatar
tc
The people I have talked to that run the no-slip have some pretty high praise. It sounds like it behaves almost identically to a full detroit locker.
Biggest issue IMHO is that it still uses the stock carrier which CAN be a weak point in the diff. Both the Detroit locker and ARB carriers are significantly stronger than stock.
Old Dec 1, 2008 | 07:46 PM
INFINITY's Avatar
the powertrax "no slip" is almost identical to the lockright but is quieter and more streetable. i love my lockright. all kind of depends on what you want to spend. lots of info out there on them just search lockright or locker
Old Dec 1, 2008 | 08:16 PM
JD91T's Avatar
Thanks guys, That's what I wanted to hear. I've got 91 w/31's and soon to be a set of 4.56 diffs... thought it would be an opportune time to add a locker too. Pretty tired of getting stuck bc one of my rears is in the air... which seems to be all too often on the trail.
-Josh
Old Dec 1, 2008 | 09:04 PM
stagger_lee's Avatar
You get what you pay for. Get a full detroit.
Old Dec 2, 2008 | 03:25 PM
Matt16's Avatar
That is the single most over used phrase on this board, and it annoys me. I don't think that always true either. Have you had a Powertrax No Slip fail on you? If so (and only then) are you really qualified to make that statement. No Slips are nearly the price of a full Detroit (minus install), so that statement doesn't even really apply.
Theoretically, a lunchbox locker could crack a carrier, but in all the research I did on lunchbox lockers, I think I came across one instance where this happened.
Sure, a Detroit is stronger, but the important question is whether or not the Powertrax is strong enough? Almost certainly.
Old Dec 3, 2008 | 04:15 PM
94yota05gto's Avatar
i had a lockrite and it worked great, i had no problems out of it
Old Dec 3, 2008 | 04:40 PM
904_runner's Avatar
X2, same here, I like the lockright!
I actually broke a pin though. But i also drove 30ish miles on a broken rear axle shaft, so idk that might have had something to do with it.
TheBFA
Feb 15, 2020 06:55 AM
83yotastockR
11
Nov 10, 2015 06:54 AM
Toys4parts
Sep 26, 2015 01:56 PM
toyotasaurus
Sep 24, 2015 03:30 PM
zz_denis
Sep 6, 2015 03:43 PM
