Need Help!!! steering issues!!!
Old Jun 1, 2008 | 01:09 PM
rlgraham69's Avatar
I have a 1979 yota 8 inches of suspension lift no body lift and I'm running a set of 38.5 gumbos. I went out playing the other day and broke my front driveshaft so I just continued in 2 wheel drive. I hit a mound of dirt and bent the link that connects the two front wheels!( anything I can use to make this stronger or is there something out there that is sold for this issue???) also the arm that drops from the steering box and connects to the drivers front wheel bent! it was home made where can I find one that will be stronger??? any info will help! Thanks,Richard
Please PM with any info. Thanks
Old Jun 1, 2008 | 09:28 PM
Blizzard's Avatar
You can put a hysteer kit on if you don't have it already.
David
Old Jun 2, 2008 | 06:09 AM
dirtoyboy's Avatar
Lets see some pics of this 8 inch lift and your steering set up
Old Jun 2, 2008 | 08:07 AM
4Crawler's Avatar
If you are stuck on the stock push-pull setup, you can sleeve the tie rod (connects the two wheels together) or maybe get ahold of a tie rod from one of the crossover steering vendors. Use the FJ80 tie rod ends and the heavy DOM tubing tie rod and it'll hold up better. On the drag link, assume you must have a dropped drag link (an S-shaped one). If so, and yours bent more, probably best to replace it and then brace it up with some gussets.
Or pop for a crossover steering kit as mentioned above, that will lift the steering up above the spring and make it nearly bullet proof:
http://www.4crawler.com/4x4/CheapTri...ng/index.shtml
Zpd426
Jan 2, 2016 01:15 PM
Up&Down
Aug 11, 2015 10:04 AM
gillesdetrail
Aug 3, 2015 04:43 PM
gmonnie123
Jul 26, 2015 02:44 PM
yoterr
Jul 24, 2015 04:29 AM
