More under axle clearence
Old May 28, 2007 | 07:18 PM
premirrider's Avatar
I have a 98 tacoma with 33's. I was wondering what brand of lift gives the best under axle clearence, or how to get more with out bigger tires or a sas. I want to keep my IFS. Thanks for any info.
Old May 28, 2007 | 07:24 PM
YM13's Avatar
I think the only way to increase the under axle lift would be to put bigger tires on....I may be wrong
From the way I see it, the axle is a straight tube that locks to the center of the wheel...there is no way that I can think of that will push it up unless you add bigger tires...On the front IFS maybe...
BTW Welcome to Yotatech..
Old May 28, 2007 | 07:46 PM
Tofer's Avatar
Sponsor
the only way to get more clearance under the axle is run bigger tires.... IFS usually doesnt like running 35s if you wheel it hard.
Old May 28, 2007 | 08:10 PM
pepsibluefloat's Avatar
http://www.chaosfab.com/tacomalong.html
Old May 28, 2007 | 08:27 PM
YM13's Avatar
Originally Posted by pepsibluefloat
Looks sweet...what exactly does it do??
I read all of the features and stuff but didn't quite understand.....does it offer any lift or does it somehow make travel greater?? Sorry if stupid question...
Old May 28, 2007 | 08:39 PM
basically makes the arms longer which makes your stance wider. I'm pretty sure it adds some lift. It does add wheel travel though
Old May 28, 2007 | 08:48 PM
YM13's Avatar
Yah I got the wheel travel part...looks like there is a lot more room between the wheel-well and the tire...I like it
Old May 28, 2007 | 08:52 PM
AxleIke's Avatar
That will increase clearance under the front, but not the rear. Simple coil spacers will also increase front clearance at a fraction of the cost.
The only way to gain clearance under the rear axle is either to shave the axle, which will give you perhaps another inch, or to put on bigger tires.
Old May 28, 2007 | 08:53 PM
harpen123's Avatar
IFS system under H1 hummers is pretty cool or axles with portals. IE volvos or unimogs.
Old May 28, 2007 | 08:54 PM
AxleIke's Avatar
it is a nice kit. You pay for it, but they have super fine quality.
Old May 29, 2007 | 02:54 PM
tc's Avatar
tc
ONLY 2 ways to gain clearance under the axles:
tire DIAMETER
-or-
portal type axles
So, taller tires are the only feasible way. Note that I am being very specific, not saying "bigger" tires. You can fit a taller tire if it's narrower.
If you've got 33's under a Taco, you already have some lift on there - gonna need A LOT more details before we can help you:
- Exactly what size tires do you have now?
- What rims? What's the backspacing?
- What lift?
TheBFA
Feb 15, 2020 06:55 AM
live4soccer7
May 11, 2016 06:52 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
Toys4parts
Sep 26, 2015 01:56 PM
