Looking for an add-a-leaf
Old Oct 9, 2005 | 12:11 PM
brandontrek's Avatar
what do you recommend? I am new to 4 wheel drive suspensions...all of my modding skills are with volkswagens(last car i owned was a jetta and i replaced everthing myself...from engines to the entire suspension). This is my first 4 wheel drive that i have been able to play with. I have a little bit of sag in my rear end. I want to keep it a strong as possible(i don't know why, i don't haul anything) bit i want the rear to sit just a little higher...oh and are they hard to replace...they don't look to difficult...thanks
Old Oct 9, 2005 | 12:18 PM
4Crawler's Avatar
If you are happy with the ride and you don't carry a lot of heavy cargo, then the shackle is easy to add. Only requires removing the shackles from the rear of the springs and putting the new ones on:
http://www.4crawler.com/4x4/ForSale/...l#Installation
An add-a-leaf will stiffen the springs a bit, giving a firmer ride and more cargo capacity without bottoming out. They will be a bit more work to install, as the u-bolts need to come off, etc.:
http://www.4crawler.com/Diesel/Cheap...l#Add-a-leaves
Just avoind "cheap" AALs that are short and thick. They are STIFF and so stiff in fact that they can force your existing springs to bend around the stiff ends of the AAL and cause them to kink and even break there.
Old Oct 9, 2005 | 12:45 PM
bob200587's Avatar
Originally Posted by nmtoy
You could also use longer rear shackles instead of an AAL. The shackles will give lift without changing the way the truck rides. The better ones also come with new polyurethane bushing for the spring and frame.
Robb
If you tow anything, ever or have alot of cargo, I would go with AAL instead, to be honest, I didn't even notice the change in the ride, it made a difference in cornering, but any lift will do that. its nice having it a little stiffer when off road anyways.
nick325i
Sep 18, 2007 07:47 AM
mehret
Sep 7, 2006 02:54 PM
YeloSub7
Mar 6, 2006 03:35 AM
Bob_98SR5
Jan 14, 2006 07:56 PM
4Runner1988
13
Sep 27, 2004 05:47 PM
