Lifting my 1997 toyota t100! need opinions asap!
Old Oct 6, 2007 | 04:47 PM
Old Light's Avatar
Wink Lifting my 1997 toyota t100! need opinions asap!
Hey Y'all
ive ordered a set of Sdori balljoint spacers few weeks ago, i just had them installed- i am going through a small dilemma. i called several off road shops about my situation.
i need to lift the rear to level out- from what ive read, blocks is out of picture as it ll warp the axle. so im left with two options- bigger shackles or add a leaf.
i have used the search button and i havent gotten a direct answer. where can i locate these parts to make it work?
Old Oct 6, 2007 | 04:50 PM
CJM's Avatar
CJM
Deaver makes a progressive (read 3 leaf pack that replaces the overload leaf) leaf pack that lifts 1.5". its for the 1st gen tundra but it will fit a T100. Get that and some longer shackles and your set.
Link: http://www.wheelersoffroad.com/donahoetundra.htm
Its under "Deaver Racing 1.5" Lift Progressive Add A Leaf Kit: 209.00 Replaces factory overload with a 3 leaf progressive add a leaf kit. Includes U-bolts."
Old Oct 6, 2007 | 04:55 PM
Old Light's Avatar
cheers! thanks for a quick reply
probably a stupid question, can i just run bigger shackles to accomplish 1.5 lift in rear?
Old Oct 6, 2007 | 05:03 PM
CJM's Avatar
CJM
Yes you can, but personally I would run both a longer shackle and a leaf pack so it flexs better.
All you need to run 33's is a 3" suspension lift and properly backspaced wheels.
Old Oct 9, 2007 | 02:18 PM
Old Light's Avatar
i just ordered longer shackles from downey which will raise about 2 inch in rear to level the truck out, im looking for good quality shocks. any suggestions? would bilstein HDS work on my combo?
let me know asap!
cheers
charles
Jun 1, 2021 01:51 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
skoti89
Jul 6, 2015 07:45 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
Vargntucson
Jul 4, 2015 12:15 PM
