Lifting a 97 TACOMA?
Old Oct 11, 2004 | 06:44 PM
Tacoma750's Avatar
Hey guys. Im looking into lifting a 97 or up TACOMA. I want to run 35s or 38s. What lift should i use? And what gears? Aslo, what other mods will i need? THX
Old Oct 11, 2004 | 08:12 PM
superjoe83's Avatar
i would suggest a SAS (Solid Axle Swap) if your going to wheel the thing, because IFS strength limit is pretty much 33's if you don't drive like a grandma, if its just going to be a street queen, then do a 6" suspension, fabtech makes one and there are some other companies out there too, and possibly a body lift if you need it, i would run 5.29's with 38's and a five speed or auto, and 4.88's with 35's and a 5 speed, if a auto i would go with 5.29' with 35's
Old Oct 12, 2004 | 03:17 AM
Tacoma750's Avatar
OK, So i cant run 35s or 38s with IFS?that sux. How much is an SAS and where can i get the steps and pictures of a SAS? I know how to weld and could do it myself.
Old Oct 12, 2004 | 08:20 AM
Pretacopower's Avatar
Search. There's probably more threads on SAS (and tires) on this forum than any other topic.
Check out Pirate too, they've got alot of info there.
Oh, and it won't be cheap
Old Oct 12, 2004 | 11:06 AM
Tacoma750's Avatar
Its not cheap = me not doin it. I'll wheel it until it breaks. Then od the SAS
Old Oct 12, 2004 | 01:39 PM
4Crawler's Avatar
http://www.4Crawler.com/4x4/ForSale/BodyLiftKit.shtml#FAQ10 Wheel it uptil you wear out the IFS, steering rack, etc. then do a SAS.
Old Oct 12, 2004 | 08:17 PM
backyard_motorsports's Avatar
from what i have read on here, you can run like a basic 3" suspension plus a body lift which could allow the fittment of 35". you can buy the body lift from 4crawler. iam in the process of doing 3" suspension plus 2" body and this will allow 33" to fit nice, as for gears!! if it is a street/ highway and some dirt, a high 4.50's would work out fine
Old Oct 13, 2004 | 03:13 AM
Tacoma750's Avatar
om probably gonna by the 6 inch lift kit from..I forget the brand. Is it skyjacker?or one of them. Would that give me enough room for 35s?
Old Oct 20, 2004 | 11:03 AM
yes this will allow 35's. i know a guy where i live and he has the skyjacker lift and he has 35's on his truck.
Old Oct 21, 2004 | 09:02 AM
Tacoma750's Avatar
What axle should i use for the 35s? Is the stock axle ok?
Old Oct 21, 2004 | 01:45 PM
well this guy that i know has the trd axle. The ring gear dia. is bigger than the non trd version. BBut what i had heard is that the non trd axle is stronger than the trd because it has the carrier bearing support brackets. so i would stick with the stock but add a locker or Limited slip
Flying91
45
Apr 11, 2024 04:39 PM
makemusic116
Aug 2, 2015 05:23 PM
makemusic116
Aug 2, 2015 04:40 AM
Yotoder865
Jul 9, 2015 07:51 PM
akaphilly
Jul 9, 2015 02:18 PM
