I'm having a lot of problems with my milemarker
Old Jan 22, 2007 | 12:11 PM
harpen123's Avatar
I have the hydraulic milemarker 10,500. It has almost no pulling power the speed of it seems normal. Also I can't get it to work in low gear. just wondering if anyone else has had many problems or knows how to fix this.
Old Jan 22, 2007 | 01:30 PM
Corey's Avatar
Co-Founder/Administrator
I swear I have read on many a forum that the Milemarker hydraulic is useless with Toyotas.
I read that the Toyota power steering pump does not have the pressure required to run it.
I could be mistaken, but it seems I have read that more than once.
Good reason to go with an electric one too is if your engine is hydrolocked in a body of water.
No engine/no hydraulic winch.
Old Jan 22, 2007 | 01:37 PM
chimmike's Avatar
it's been said numerous times on here, for sure.
Old Jan 22, 2007 | 01:55 PM
Corey's Avatar
PM this guy.
https://www.yotatech.com/forums/show...rker+hydraulic
He installed his close to two years ago, and last logged in here the 8th of this month.
I am sure he can fill you in how his has been working.
Old Jan 22, 2007 | 02:07 PM
harpen123's Avatar
I have a buddy with a o3 tacoma with the same winch. He bought his truck with his on it, and helped me put mine on. His works pretty good and I was kinda wondering if I have put it on wrong or what. I will probably contact milemarker but I have already had to repair part of the winch with them. Basically since Ive had the winch it has never really been fully operational.
Old Jan 22, 2007 | 02:39 PM
harpen123's Avatar
I was so pissed when I was stuck and trying to use it and someone goes "its just for decoration" If he wasnt a friend I would have jacked him in the mouth but i really am starting to feel like my 750 dollar winch is a 75 lb paper weight.
Old Jan 25, 2007 | 08:37 AM
harpen123's Avatar
well anyone put a stronger ps pump in their truck. Where to find one. Use like a tundra one?
Old Jan 25, 2007 | 09:23 AM
Flygtenstein's Avatar
Congratulations on showing why most people run Warn electrics.
PSC makes a pump, it is going to be spendy but worth it to make the rest of what you have work.
Old Jan 25, 2007 | 10:14 AM
NPE701's Avatar
You, guys, are not very helpful here. Whatever that winch is, instead of giving useful advice most of the posts here basically say "haha, I told ya electric Warn is better".
If the winch is installed correctly, with the correct adapters - check the power steering pump and possibly consider a high-output pump to replace the stock one with.
Old Jan 25, 2007 | 10:20 AM
91TPU's Avatar
sorry that we are all not a nice as you...
basically from what i know the only solution to your problem is to run a different power steering pump...and since you already have invested 750 in the winch, your prolly better off getting the pump then buying a whole new winch...
Old Jan 25, 2007 | 10:25 AM
NPE701's Avatar
Don't be ridiculous. Work on your spelling instead.
Old Jan 25, 2007 | 10:46 AM
Did you see the rest of the post?
Get a PSC pump. They have a kit to put essentially an upgraded GM pump on that people usually run for assit or full hydro. I run one, but it is for assist on a 3.4
We are being helpful, just read the posts.
Old Jan 28, 2007 | 08:08 PM
harpen123's Avatar
the low gear pin is stuck so ive contacted milemarker about fixing it and I am looking for a stronger power steering pump. ANy other recommendations are appreciated.
Old Jan 28, 2007 | 08:09 PM
harpen123's Avatar
not to sound like an idiot but does anyone have the website for PSC.
Old Jan 28, 2007 | 08:14 PM
marko3xl3's Avatar
http://www.pscpowersteer.com/
Old Jan 28, 2007 | 08:29 PM
harpen123's Avatar
http://www.pscmotorsports.com/produc...3d5361ed0f5015
can I use the stock reservoir and pulley on this or is the 412 dollar install kit a must?
Old Feb 1, 2007 | 01:37 PM
harpen123's Avatar
sooo.... guessing noone knows
Charecter1
Nov 6, 2023 10:08 AM
the1998sr5
15
Jul 14, 2020 08:35 PM
Eggslinger
Jun 8, 2019 03:32 PM
jasonty
41
Dec 23, 2018 01:00 PM
Jnkml
Jul 6, 2015 01:20 PM
