IFS taco diff
IFS taco diff
i know that 96-02 4Runners have the same gears and housing as the 96-04 Tacomas, but are the diffs interchangable or do the Taco diffs have a different spline count than 4Runners?
basically, can a taco diff be put into a 4Runner without swapping axles and hubs?
its all the same, as long as you have ADD and it have ADD.. also if you have v6 and it came from a V6 it should be the same. CV joins are all the same, only difference is on the hib site of a CV.. other then that, get it
Originally posted by data
the diff already has a locker in it? what kind of locker is it? if you're only running a front locker be prepared to replace cv's left and right
i def want the 4.88s, dunno about the lockright.
im going to install the diff and see how i like the Automatic locker, if i dont like, ill remove and ebay it.
If it were auto, i'd get manual hubs. I had a friend with a Taco with only a front locker and manual hubs. He broke cv's all the time. Seeing the 4runner is heavier, it might turn you into a pro 15 minute cv changer
Do you already have 4.88's in the rear diff? For some reason, I don't think everything is the same for the 4runner and Tacoma front diffs, possible outer cv's are different? I'm thinking along the lines of the ORS kit and what needs to be changed to put on manual hubs, I realize its a somewhat unrelated topic.... Steve would be the one to chime in on this one.
For some reason, I don't think everything is the same for the 4runner and Tacoma front diffs, possible outer cv's are different? I'm thinking along the lines of the ORS kit and what needs to be changed to put on manual hubs...
See my other post regarding the ADD actuators. Depending on the year of the Taco that is the donor, you may be getting vacuum actuated ADD or electric actuated ADD. Chances are that the ADD on your 4runner is the vacuum type ('98-'00)
justdifferentials
14
Jun 11, 2017 08:36 PM
zz_denis
Sep 6, 2015 03:43 PM
