IFS ARB Install and E-Lcoker Retrofit Write-up
IFS ARB Install and E-Locker Retrofit Write-up
Here's a short write-up of my recent install:
http://www.geocities.com/transalper/lockers.htm
I got to test out the lockers again this week on a trail through a floodplain that's usually under water except during the driest part of the summer or during a drought. It's amazing how quickly it will try to slide sideways down a muddy, off-camber hill when both ends are locked.
doin' the sideways crab walk-
yup, that is typical of dual locked rigs. It will happen in virtually any type of terrain that you spin tires on, or even loose gravel.
Ice is real fun- I've been on pavement with zero forward speed and just kinda slid right down the crown of the road to the curb w/ all four spinning very slowly. it's kind of a helpless feeling. I generally just stay in 2x4 and air down.
HAVE FUN!
HAVE FUN!
HAVE FUN!
HAVE FUN!
do you really have your winch hooked into the mirror switch? that's awesome!
edit: nevermind...just read about it on your website. cool idea
Where'd you get the ARB setup for the front? I'm trying to find the easiest and most cost effective way to get one for the front of my 4runner too, but most of the companies I've emailed never return them. I'm sure a phone call would work, but I'm in the research phase right now. I'd like a complete third or assembly(whicheve it is), so all I'd have to do is install the compressor, run the lines, and replace the assembly with the new ARB equipped one. Any recommendations?
Chris
Chris
Originally posted by ravencr
Where'd you get the ARB setup for the front? I'd like a complete third or assembly(whicheve it is), so all I'd have to do is install the compressor, run the lines, and replace the assembly with the new ARB equipped one. Any recommendations?
Chris
Chris
Using the ARB compressor is the easiest and cheapest option, but it is a weak unit. There are better compressors out there for not that much more moola.
So, you buy the diff housing used so they can install the ARB into it, right? And, once you install it in your 4runner, they refund you a core charge on your existing diff housing, right? I'd really like to buy a complete third if it's the easiest way to attack this, but if there's a cheaper and not much harder, I'm all ears.
Chris
Chris
Chris
Chris
So is the reason you bought the used diff so you wouldn't have as much downtime? Could I save that money too, if I removed everything from the truck, bought the ARB separate from Mike, and then had a shop install the ARB in the housing along with the gears, and then install the diff back into the truck?
Chris
Chris
Chris
Chris
Hoe'd you determine what gears you had, and what gears you found on the used diff? I want to go with 4.88's
Chris
Chris
I do not know how much the gears cost or how much that adds to the install cost. My guess is that if you are going with 4.88s then you may as well get a built complete diff. IMHO, if you are really concerned about saving some money, then I would look into finding a used front IFS diff with 4.56s and then just swapping 4.56s into your rear 3rd (you have a limited, so already have the e-locker, right?). You might actually be able to save money for the rear gear swap by getting a used e-locker 3rd that already has the 4.56s. That way you could do all the labor for the rear yourself and then sell your current e-locker 3rd. Finding decent front and rear diffs wtih 4.56s will be a feat though. For me, 4.30s are great with my 265/75R16s and are a good on/off road compromise.
Chris if you plan on going 4.88's up front, you're going to have to regear the rear also.
If I plan on building up my rig more, I'm going with 4.88's and arbs fr/rr. But most likely I'll have to buy everything new or put together already, and pay a shop to do it (which will cost a fortune) which is why I'm holding off to see what the future holds and if I wanna build up more or not.
I'm going to probably get 4.88's front and rear, and get a fully built ARB'd third up front. I know today out on the difficult trails at Windrock, I could have definitely used on up front a couple of times. Plus, I hate where the gas tank is located on our vehicles, and that's something else I'm going to change in the near future too.
Chris
Chris
Do you have manual hubs. Isnt it recomended that you have them with a front locker, even an ARB. Or am i mistaken on this. I am looking at installing my lockers installed over christmas, tryin to figure this whole thing out.
I suppose front auto lockers like lockrights would force the driveshaft to spin all the time unless manual hubs are installed.
delmert
Sep 30, 2015 04:34 PM
coffey50
Jul 28, 2015 10:55 AM
