graphite as bushing lube?
Old Aug 16, 2013 | 11:10 PM
Inu's Avatar
Inu
As stated, anyone use dry graphite only to lube polybushings? I hate the dust collection on my a arm bushings. Ive found people added it to the grease to stop squeaks but not alone. I live in the desert so the only water is from when i wash the truck.
Any thoughts before i put this back together?
Old Aug 17, 2013 | 09:24 AM
4Crawler's Avatar
Never tried plain graphite, but have used both graphite grease and graphite paint (Lubriplate Slip-Plate)on leaf spring bushings and in between spring leaves. Over time, both will build up a layer of graphite powder in between the moving parts and usually quiet the squeaking. I find it does take a few applications over a few years to build up the graphite layer, basically run it until it starts squeaking then reapply. On the grease, I'll usually just brush it on just where needed and the dust collection is not too bad. Wash off the dust buildup a few times and the dust will take most of the excess grease away.
Old Aug 17, 2013 | 03:26 PM
Inu's Avatar
Inu
Thanks. Id forgotten about speedcoat type paints. Picked up some powder gonna try one arm and see how it goes after working it in.
Old Aug 17, 2013 | 03:54 PM
gigatech88's Avatar
Dry lube for motorcycle/bicycle chains works great. It doesn't attract dirt as grease does. Hell mix it with some powdered graphite if ya want
Old Aug 17, 2013 | 05:43 PM
INFINITY's Avatar
napa makes a dry graphite spray. goes on wet and dries quickly, good stuff but not cheap.
i believe energyy sus or prothane makes their black bushings impregnated with graphite, or so i remember reading???
Old Aug 17, 2013 | 06:00 PM
gigatech88's Avatar
That spray is great. But never actually dries. I use it all day long on lug nuts mostly. Months later when a car comes back for service or another repair, that graphite is still wet just as it came out of the can.
Old Aug 17, 2013 | 06:22 PM
Inu's Avatar
Inu
Follow up. Graphite by itself is meh...no squeak but also very binding still, settled on grease with graphite.
Old Aug 17, 2013 | 06:26 PM
Inu's Avatar
Inu
Refresh before posting....doh... ive got prothane on upper and lowers. Sticky buggers even lubed. TS said they'll break in and loosen up after some use, brings the suck on the ramp or slow crawling.
Old Aug 18, 2013 | 07:45 PM
INFINITY's Avatar
i dont think we are talking about the same spray. the stuff i am talking about dries almost immediately. we use it on road grader boards
Old Aug 18, 2013 | 09:01 PM
gigatech88's Avatar
Graphite spray. Aerosol can. Possibly a red can. The stuff I use never actually dries. We probably are speaking of two different products.
kawazx636
Oct 6, 2021 03:03 PM
live4soccer7
May 11, 2016 06:52 PM
punks_is_4x4
Feb 26, 2016 04:29 PM
JRB4Runner2015
Sep 20, 2015 12:29 AM
Pocoyota
Sep 8, 2015 02:41 PM
