Gas Tank lift & clearance
Old Sep 2, 2009 | 12:55 PM
4Yoter's Avatar
I want to raise my gas tank up from the stock position on my 1991 4runner. I have a 2" lift and woud lift to gain more clearance without replacing the stock gas tank. Also does anyone have a link about raising the bulking crossmember under the transfer case or a less bulky (yet still strong) replacement for it
Thx
Old Sep 2, 2009 | 01:23 PM
4Crawler's Avatar
Not as easy on a 2nd gen, at least if you plan to retain the rear coil suspension:
- http://www.4crawler.com/4x4/CheapTri....shtml#GasTank
Here is an option for raising the gas tank on a 2nd gen 4Runner that avoids the rear suspension brackets:
- http://www.4x4wire.com/toyota/tech/gas_tank/
And lots of t-case cross member options:
- http://www.4crawler.com/4x4/ForSale/...l#TcaseXmember
Old Sep 2, 2009 | 03:29 PM
tc's Avatar
tc
How badly do you want to do it?
Old Sep 2, 2009 | 10:28 PM
4Yoter's Avatar
Prtty bad cause the trails out here are prrty rock filled. I think ima go with the crossmember from budbuilt
http://www.budbuilt.com/new/dual_cross_members.html
Unless i can find one for a cheaper price, but i like the design of the budbuilt.
Another question was that in the 1st gen 4runner there is a aux mounting point for the gas tank. what do u guys think about if I were to mount the gas tank on the top of the hoarse collar instead of it being on the inside of it.
Old Sep 2, 2009 | 10:31 PM
4Yoter's Avatar
Or there is also the cross member from 4x
http://www.4xinnovations.com/pages/d...ossmembers.htm
Except i wold still like a skid plate on the bottom of that one.
Old Sep 3, 2009 | 05:53 AM
4Crawler's Avatar
With the rear coil suspension, some of the control arm mounting points sit above the gas tank and raising the tank in place is quite difficult.
Old Sep 3, 2009 | 10:44 AM
4Yoter's Avatar
gaahhhhh The tank sits way to low for my liking ugh ill figure something out
Old Sep 4, 2009 | 09:43 AM
AxleIke's Avatar
Mine us up out of the way:
Old Sep 4, 2009 | 01:12 PM
Duckie's Avatar
A Tucsonan! I'm also interested in way of getting it up and out of the way, but i'm gonna wait until I have another DD. AxelIkes build thread is aweosme if your curious.
Old Sep 4, 2009 | 01:28 PM
tc's Avatar
tc
Still need a skid on there Isaac ... and you have that new plasma cutter to break in ...
Old Sep 4, 2009 | 02:03 PM
AxleIke's Avatar
Meh, I'll get the skid there eventually. The plasma will certainly make that easier.
I'm also putting in more fuel pickups (snow mobile) in the tank, as well as redoing the high pressure side with SS flex line and -6AN.
Old Sep 11, 2009 | 05:45 PM
Matt16's Avatar
AxleIke, do you find the truck to be tippier with the new suspension? Your panhard is at quite an angle and thus IIRC your roll centre should be quite elevated and thus tippy.
Old Sep 13, 2009 | 07:19 PM
AxleIke's Avatar
No, its not tippy at all. High roll centre is good. You don't want a low roll centre.
Old Sep 13, 2009 | 08:10 PM
tc's Avatar
tc
Huh? Care to explain this one, cuz it goes counter to everything I know about suspension design ...
Old Sep 13, 2009 | 08:12 PM
BLKNBLU's Avatar
Here is another idea to kick around. Starts on post #2.
https://www.yotatech.com/forums/f88/...-heavy-132060/
Old Sep 14, 2009 | 05:42 AM
AxleIke's Avatar
Roll center is the point at which the body wants to rotate around the axle. A low roll center equals LOTS of body roll, especially on side slopes/off camber. A high roll center is more stable. Its sort of hard to describe on the net, but if you do it with your hands, you'll see what I'm talking about.
On a three link like mine, the roll center is in the middle of the panhard rod.
This thread is a great read, but for a quick, and better explanation, check out post 33:
http://pirate4x4.com/forum/showthrea...re#post1853820
Old Sep 14, 2009 | 11:06 AM
tc's Avatar
tc
I think that poster's last sentence says it all ...
Here's an article from a published authority, although, he doesn't quite boil it down as far...
http://www.neohio-scca.org/comp_clin...namics2007.pdf
... and the article I referred to when designing mine ...
http://www.avalancheengineering.com/july2003.htm
I can tell you I dropped my roll center quite a bit and the truck is way more stable now.
Old Sep 14, 2009 | 11:37 AM
AxleIke's Avatar
Mine feels very stable with the higher roll center. Think about it using your hands, both facing palm down on top of each other, separated by a few inches.
Imagine a line along the top of your lower hand. Imagine your lower hand is the axle and the upper hand is your body. If you rotate about this imaginary line, you will see that your upper hand (the body) has signifcant side to side motion.
Now, do the same thing, but imagine the line going down the bottom of your upper hand. This would be a high roll centre. As you rotate about that, notice that the body stays MUCH more centered over the axle, and thus is more stable.
Old Sep 14, 2009 | 11:46 AM
AxleIke's Avatar
Also, if you read through a lot of the other link threads, people are going for high roll centers on all the buggy builds, to gain stability.
Old Sep 14, 2009 | 11:59 AM
AxleIke's Avatar
Also, to keep in mind, a 3 link has a roll center: which is located at a height equal to the midpoint of the panhard rod.
In a 4 link, the interest is more in the roll axis, and keeping it as flat as possible. You've done that by double triangulating the links. Your roll center should be equal to the height of the midpoint of your upper/lower intersections, which is likely higher than mine. But, with the double triangulation, you will have a fairly flat roll axis, which is good.
