full width sas shackle help
Old Mar 14, 2012 | 07:12 PM
stamp's Avatar
ive seen HUNDREDS of full width sas pictures of the front spring hangars but not a single one of the rear without offset shackles. is there a way to do it without? or am i stuck buying shackles from a company like SKY?
Old Apr 12, 2012 | 08:59 AM
5runner's Avatar
i think another option is to cut the spring purchase and move them in... that is the only other option
Old Jul 23, 2012 | 08:48 PM
Von Wilsonator's Avatar
Ive never had an issue with running offset shackles, and apparently neither have the hundreds of others running fullwidths. Im assuming your thinking of running fullsize chevy axles. Theres no way to move in the passenger perch on a D60. its already a cast part of the housing. you have to bring both sides in equally unless your narrowing the axle by cutting down the long side. A D44 passenger perch is possible to move in, but not without a TON of dangerous Diff fab making it higher than the drivers side.
Dont run a Dodge housing, they're spring perches are even wider.
You could run a flat plate under the frame for your rear shackle, offset it to the outside, then gusset the piss outta it. But that would make your pinion angle too severe especially with a low pinion bowtie axle.
Offset shackles are your best option.
Old Jul 29, 2012 | 11:47 AM
twisted_toy's Avatar
move the spring perches in. best way to do it. i did it on my toyota with full widths 14 bolt d44 43 swampers and 3.4 swapped in!
punks_is_4x4
May 31, 2016 06:03 AM
LotOMiles
Sep 14, 2015 11:45 PM
Dparr2ndgen
Sep 8, 2015 01:06 PM
viesail
Sep 5, 2015 04:23 AM
seab1209
Sep 3, 2015 05:41 PM
