full width sas shackle help
ive seen HUNDREDS of full width sas pictures of the front spring hangars but not a single one of the rear without offset shackles. is there a way to do it without? or am i stuck buying shackles from a company like SKY?
i think another option is to cut the spring purchase and move them in... that is the only other option
Originally Posted by stamp
(Post 51886983)
Dont run a Dodge housing, they're spring perches are even wider. You could run a flat plate under the frame for your rear shackle, offset it to the outside, then gusset the piss outta it. But that would make your pinion angle too severe especially with a low pinion bowtie axle. Offset shackles are your best option. |
move the spring perches in. best way to do it. i did it on my toyota with full widths 14 bolt d44 43 swampers and 3.4 swapped in!
