full width sas shackle help
ive seen HUNDREDS of full width sas pictures of the front spring hangars but not a single one of the rear without offset shackles. is there a way to do it without? or am i stuck buying shackles from a company like SKY?
Dont run a Dodge housing, they're spring perches are even wider.
You could run a flat plate under the frame for your rear shackle, offset it to the outside, then gusset the piss outta it. But that would make your pinion angle too severe especially with a low pinion bowtie axle.
Offset shackles are your best option.
LotOMiles
Sep 14, 2015 11:45 PM
