front suspension lift problem...help
Old Aug 14, 2005 | 08:11 PM
Magreger's Avatar
I just got done installing my front super lift on my 93 runner. It just has the front lift, back is stock. I put the stock 31 tires back on and put it on the ground. now both tires are bowed out. the steering wheel is strait and both tires are pointing out a bit. WTF Is is just that my alignment is WAY off or is it something more serious, the sway bar is off and the tie rod ends are in the new mounts but not bolted tight, but that shouldnt matter. I looked at everything for a while and couldnt see anything wrong.
Any ideas, experiences, thoughts.
this whole install has been a PITA
Could the CAM bolts on my LCA's cause the wheels to bow out like each is turning out. I dont have the washer things on the back side for the nuts on the crossmembers and I took or the ones that were pressed in and put them back, but not on the exact position on the head as before, ...its a long story.
Attached Thumbnails front suspension lift problem...help-picture-3333.jpg   front suspension lift problem...help-picture-2222.jpg   front suspension lift problem...help-picture-1111.jpg
Old Aug 14, 2005 | 08:29 PM
4Crawler's Avatar
Alignment, set the toe in. To get it close, use a tape measure between the tires front and rear at the center line. Crank in the tie rod ends until you have about 1/16"-1/8" toe in, that is the front width is a bit less than the back width. THen take it to a shop and have them set the camber and toe to spec.
Old Aug 14, 2005 | 08:35 PM
r0cky's Avatar
I hate to ask a question this stupid, but just to be sure ... you tightened the lug nuts a bit before putting it back on the ground, right??
Old Aug 14, 2005 | 08:50 PM
Magreger's Avatar
Thanks Roger. I was hopeing that was the case. I hope the CAM bolt thing will not be a prob. Im gonna have to get some new tie rod ends, long story short their not gonna work. will it be ok to drive a LITTLE to a mechanic and alignment shop as is? If I leave the tie rod ends.
Old Aug 14, 2005 | 09:00 PM
Magreger's Avatar
no prob, yes I did . I double check every bolt I put on it.
Old Aug 14, 2005 | 10:41 PM
BajaRunner's Avatar
Well, rule #1 is to get an alignment after installing any sort of suspension component/lift.
You just changed the entire geometry of it, so it throws the alignment way off.
Its normal!
This is what mine looked like the second I put it on the ground:
Old Aug 14, 2005 | 11:10 PM
jimbo74's Avatar
i dont have any current pics, but i have about 2 degrees of positive camber due to my bj spacers....
driving it is fine with jacked alignment, just dont do it too long or it wiill destroy your tires.... vehicles that have severe toe out problems can destroy a set of tires in less than 300 miles!
Old Aug 14, 2005 | 11:20 PM
Magreger's Avatar
I figured it would just eat up my tires, Ill prob only put a few miles on it. just as long as it doesnt mess up my susp. I dont care. I cant wait until I put my 860's on, Ill get some pics up as soon as its all up.
Old Aug 15, 2005 | 07:05 AM
4Crawler's Avatar
Best bet is to crank things in as close as you can get it by eye before driving it, but a short distance at low speed is probably OK. Might take it out for a test drive on a vacant street before hitting any traffic first to make sure it handles OK.
Old Aug 15, 2005 | 08:35 AM
Magreger's Avatar
Will do I got a school parking lot across the street.
Jun 1, 2021 01:51 PM
Sep 4, 2015 09:27 AM
coffey50
Jul 28, 2015 10:55 AM
andrewtexas123
Jul 23, 2015 11:22 AM
Vargntucson
Jul 4, 2015 12:15 PM
