front axle seal replacement
Old May 9, 2004 | 08:45 PM
kyle_22r's Avatar
after the guy at 4wp busted off a lug stud and took apart my front hub, it dumped a bunch of gear oil out of the knuckle. kinda figured it would happen. anyhow, since i don't have the money for a total rebuild, could i just pull out my birfields and inners and put in new seals? i'm just trying to keep that gear oil out of there, i'll do a full rebuild when i get new gears in the (hopefully) near future
is this possible?
Old May 10, 2004 | 06:25 AM
Shane's Avatar
Yes. Use a thin coat of RTV where the paper gaskets are on the spindle and you'll be fine. You also should seperate the birfs so you can properly clean them out and repack, so also pick up a couple of the little wire snap rings that hold them together. If the seal went because of wear on the brass bushing in the spindle it'll likely fail again soon though.
Old May 10, 2004 | 12:31 PM
toy283's Avatar
Once you pull the inner axles the inner seal will be right there. Problem is, it's kinda deep inside the axle tube and can be quite difficult to remove. I usually use a slide-hammer but you could sacrifice a screwdriver by bending it 90° at the appropriate location.
Old May 10, 2004 | 12:50 PM
Shane's Avatar
Or just get one of these
6th Gear
19
Dec 10, 2019 07:31 AM
voiddweller
19
May 2, 2016 09:10 PM
Jmiller1023
23
Aug 6, 2015 07:03 PM
Robinhood150
Jul 24, 2002 11:08 AM
