Dual Transfer Case Question
Old May 9, 2006 | 06:22 AM
Yotaboy's Avatar
I was thinking of putting a dual Toyota case on my 88 4Runner 5spd. What I want to know is that is it going to effect drivablity. I would not think so but I want to know for sure. The other question is when I legthen my front driveshaft are people getting them made or just legthening the orignal. Thanks for the help.
Old May 9, 2006 | 03:33 PM
superjoe83's Avatar
driveability should not change
you can lengthen your current drive shaft
Old May 10, 2006 | 03:46 AM
Yotaboy's Avatar
Thanks for the reply
Old May 13, 2006 | 06:43 PM
BeaterToyota's Avatar
I have an '88 with dual cases. Driveability is not affected by doing dual cases.
Where in VA are you? I had my rear shaft shortened and my front shaft lengthened by a heavy truck spring shop in Sterling. I think the place is called Chantilly Spring Works. They generally do dump truck springs, but I got my shafts done there and they have made me custom leafspring u-bolts a couple of times.
Old May 16, 2006 | 11:17 AM
getitdone's Avatar
Make a square shaft for the front(much cheaper/stronger). Search pirate or just ask superjoe83. He has one.
Old Jun 1, 2006 | 08:01 AM
Yotaboy's Avatar
Im on the coast. I talked to Stardard Machine shop in Chesapeake and they said they would have to see them first. He said that on some of the imports they have to make a whole new drive shaft. How much did yall spend at the machine shop? I dont think a square shaft would be good because you cant balance it, maybe Im wrong. Ive heard of people using the rear shaft on the front. Can you do that ? Do I need to get ride of the cv joint on the front shaft?
Old Jun 1, 2006 | 08:12 AM
AxleIke's Avatar
Do not make a square shaft unless you NEVER run on the road in 4wheel drive, for example, if you never get snow. You probably can't safely run a square shaft at much above 20 or so.
Key word there is safely, i'm sure people have done it, it's just a dumb idea.
Old Jun 1, 2006 | 09:11 AM
getitdone's Avatar
Not when it's sleeved with uhmw polyethylene.
PNWrider
Oct 30, 2015 08:14 AM
ViperTT
Aug 14, 2015 05:27 AM
yourrealdad
Jul 29, 2015 11:08 AM
mYnAmEiSmUd
Jul 20, 2015 06:48 AM
crashburnoveride
Jul 10, 2015 06:39 AM
