Diff gears question...
Old Nov 16, 2005 | 07:48 PM
Keggo's Avatar
Hey guys... Just won some 5.29's from Mark (formulatoy), but they are for a 4Cyl... Is there any way at least one set would work for my rear diff ('91 V6) since they are the 8" R&P's? Or will I just have to sell these to a person with a need for two sets (or just one)? Thanks!
Old Nov 16, 2005 | 08:03 PM
EWAYota's Avatar
I'd lean more towards the side of No. I think the only way you could do it is if you were to switch 3rd's, and even still I dont think that would work. Might be wrong, but I think you can go from a 4 to a 6, but not the other way around
If you do end up selling them, let me know, I'd be intrested in purchasing them off of you if the price is right.
Old Nov 16, 2005 | 09:09 PM
Keggo's Avatar
Cool, that's what I was thinking. I probably won't be going to 35's for a while... (if ever) so... You may see them in the classifieds here shortly. If I can't use them at all, then I will be selling them.
Old Nov 16, 2005 | 09:41 PM
superjoe83's Avatar
There are actually two types of R&P, let's call them "LPH" (Long Pinion Head) and "SPH" (Short Pinion Head).
- '79-'85 rigs have SPH gears and a "thick" inner pinion bearing designed for the 4cyl housing. All aftermarket "4cyl" R&P and inner pinion bearings are identical to these factory parts, that way the same part numbers will fit all '79-'95 four-cylinder rigs.
- '86-'95 four-cylinder and V6 rigs ALL come with LPH gears. However, to use LPH gears in a four-cylinder housing you MUST use the "thin" '86-'95 factory Toyota four-cylinder inner pinion bearing. If you use a "thick" aftermarket bearing (or a factory '79-'85 bearing) the pinion will be too deep into the mesh and won't work.
- SPH gears will fit V6 housings if you add a lot of inner pinion bearing shims. Precision Gear avoids having to use so many shims by offering an aftermarket LPH gearset for V6 housings.
does this help? looks like they will work
Old Nov 16, 2005 | 10:10 PM
EWAYota's Avatar
Joe, what website did you find that? I was doing a little research on this to help Kevin try and figure out how to make it work, but never came upon that info.
Old Nov 16, 2005 | 11:10 PM
BajaRunner's Avatar
As long as they are for the 8" rear diffs, they will work.
Here is a good toyota diff page:
http://home.4x4wire.com/erik/diffs/
Old Nov 17, 2005 | 03:30 AM
Ganoid's Avatar
should work. If I remember correctly you just use a bit more pinion shims to get everything lined up.
Old Nov 17, 2005 | 04:18 AM
ZUK's Avatar
ZUK
Keggo---the 4 cyl gear will work just fine in your V6 3rd....use about a .243" pinion shim and you are good to go. I believe there to be no loss in strength either. V6 gears are harder to find and more money. What brand or markings do you have on the ring gear?
Old Nov 17, 2005 | 07:56 AM
Keggo's Avatar
Thanks for all the help guys... The gears are Yukons.
Markings:
Ring: T8-529 304
Pinion: T8-529
Old Nov 17, 2005 | 03:20 PM
ZUK's Avatar
ZUK
Markings:
Ring: T8-529 304
Pinion: T8-529
Those gears will set up just fine.....probably 240~243 on the shim. ZUK
Old Nov 17, 2005 | 10:44 PM
outdoorfever's Avatar
nice!
jashoeuh
Nov 18, 2024 08:08 AM
jerusry
Oct 19, 2015 05:28 PM
priest16
15
Aug 6, 2015 07:43 AM
yourrealdad
Jul 29, 2015 11:08 AM
Athansinis
Jul 27, 2015 08:38 AM
