D/T lift?
Old Feb 11, 2008 | 07:57 PM
hauckster's Avatar
D/T lift?
Hey so ive been doing a lot of research on the D/T lift (a 2 inch so that it will all be back into the same place after the 2 inch BL i plan) for a 2nd gen 4runner and found that some people get drive shaft vibes when they do it to there V6.
Just wondering should i look for a 4runner with different engine than a V6 if i would like to give my runner a flat belly to add more protection for the underside?
Im planning to put a 2 inch BL on my rig before i put the D/T lift on it, obviously.
Any info at all would be great.
Any info would be awsome from people who have actually done them.
Thanx
Jordon
Old Feb 12, 2008 | 08:32 AM
4Crawler's Avatar
As long as you raise the engine and transmission an equal amount (i.e raise them level) then the driveshaft angles/alignment is preserved:
- http://www.4crawler.com/4x4/ForSale/....shtml#MM_FAQ4
Old Feb 12, 2008 | 07:33 PM
hauckster's Avatar
thanx 4crawler just wondering if you would recomend a 2 or 3 inch (obviously gonna have to go with the 3 inch BL then) to tuck everything up under the frame rails so i can make it nice and smooth under there or would just a 2 inch work?
also love the website it is so helpful.
Old Feb 12, 2008 | 08:32 PM
4Crawler's Avatar
I did 2" on my '85 (w/ a 3" body lift):
- http://www.4crawler.com/4x4/CheapTri...ft/index.shtml
The extra 1" clearance is nice, makes accessing the engine and tranny easier and gives my rear driveshaft a little more clearance under the frame. Still made a huge improvement in clearance underneath (about 5.5"):
Old Feb 13, 2008 | 08:32 AM
BajaRunner's Avatar
Has anyone done this on a 3rd gen?
How hard is it to raise the engine?
Old Feb 13, 2008 | 08:35 AM
Tacoclimber's Avatar
Do you already have a BL?
Old Feb 13, 2008 | 08:36 AM
4Crawler's Avatar
It has been done, sure someone will post a link to a writeup.
Motor mount spacers are available and just bolt right in:
- http://www.4crawler.com/4x4/ForSale/MotorMount.shtml
Old Feb 13, 2008 | 08:39 AM
yotasavg's Avatar
i want to do this so badly.
Old Feb 13, 2008 | 08:42 AM
That's why i was asking if Ian already had a BL. If he does, then it's a fairly straightforward affair. This is on my future mod list, too.
Old Feb 13, 2008 | 08:56 AM
AxleIke's Avatar
A BL, and DTL is the BEST possible way to gain clearance. You get bigger tires without adversely affecting the suspension, and you get rock clearance under the belly. Cheap, effective, and works. Can't do better than that.
Old Feb 13, 2008 | 08:58 AM
Oh wait...this is for actually offroading???
Oh, never mind. I just wanted bigger tires.
Old Feb 13, 2008 | 09:08 AM
04 Rocko Taco's Avatar
CJ is my hero.
Old Feb 13, 2008 | 09:23 AM
Originally Posted by 04 Rocko Taco
CJ is my hero.
Don't get your hopes up. I trip on my cape. A lot.
Old Feb 13, 2008 | 07:36 PM
hauckster's Avatar
thanx guys for your help
my D/T lift is pretty far of down the road so ill just have to do somemore seaching and asking thanx again
jordon
Old Feb 14, 2008 | 05:00 AM
WFO's Avatar
WFO
Anyone have any info on doing a D/T lift without a body lift?
Im running 37s right now and have plenty of room for them so I dont want a BL. I'd imagine there would be some cutting to the floor but would there be enough hood clearance?
Old Feb 14, 2008 | 05:17 AM
James Dean's Avatar
Is that ground wire bolt on the frame loose?
Old Feb 14, 2008 | 05:48 AM
AxleIke's Avatar
Depends on how much you do. But you will almost certainly have to cut the hood.
Check out Filsrunner's build up. Not only is his build SICK, but he did exactly what you are talking about.
https://www.yotatech.com/forums/f88/...-heavy-132060/
Old Feb 14, 2008 | 06:41 AM
4Crawler's Avatar
Yes, took the picture while I was installing my dual battery setup and was still making up cables and connections. It was tightened before I finished up that installation. And that was an additional cable I added and just used that bolt as a common connection point for all my new ground cables.
Old Feb 15, 2008 | 10:19 AM
WFO's Avatar
WFO
Thanks for the link. Yeah thats a sweet build. It looks just like mine... well except for the DT lift sliders and 3.4.
Thats a lot of work. I might just consider lowering the suspension and adding a BL. I dont really want to go bigger than 37s and i cant have my truck out of commision for the time it would take to hack up the floor.
Dparr2ndgen
Sep 8, 2015 01:06 PM
justdifferentials
Sep 5, 2015 06:52 PM
joeynational
Sep 5, 2015 01:54 PM
matthew138
Sep 3, 2015 08:21 AM
Ryall
Sep 2, 2015 06:48 AM
