centerforce clutches
Old Feb 1, 2008 | 07:21 PM
Supra 4x4's Avatar
I have a CF Dual Friction and I can't tell that it feels any different than stock. I have dual cases and 35" tires and have had the same CF clutch now for about 5-6 years. Just pulled the tranny for a rebuild and I am not changing the clutch it still works perfectly.
Old Feb 2, 2008 | 08:49 AM
nate9207's Avatar
well thats awesome... im gonna go with it then. how did ya fit them 35s? bl or susp lift?
Old Feb 2, 2008 | 09:22 AM
4Mogger's Avatar
Originally Posted by 4Crawler
Stock flywheel is steel as well. THe CF fly wheel is heavier than stock so improves low end torque at the expense of a slower revving engine. I have the CF flywheel and it works well, helps with slow speed crawling off-road.
I also have the DF clutch and the Centerforce Flywheel. I love the combo. It really smoothes out the slow speed crawling and makes it very hard to kill in low rpm crawling.
I also have the 5.15 first gear (Japanese gearset from Marlin)
Just make sure you replace the TO bearing and pilot bearing when you put in the new clutch, have the flywheel resurfaced, AND MAKE SURE YOU USE FACTORY TOYOTA PARTS for the bearings!
Old Feb 2, 2008 | 09:30 AM
ozziesironmanoffroad's Avatar
i plan on putting a wab fab clutch in mine when im ready to replace.
Old Feb 2, 2008 | 12:55 PM
  #25
nate9207's Avatar
well iv got the centerforce throwout bearing and im plannin on gettin another pilot bearing as well. so it would be best to get a Toyota genuine pilot bearing? or just an OEM replacement from like autozone?
Old Feb 2, 2008 | 07:41 PM
  #26
4Mogger's Avatar
I used non-Toyota bearings and had a pilot bearing seize after only 10,000 miles of street use. That scored the input shaft badly and I ended up getting the transmission rebuilt. How much did that suck after springing for labor and a new clutch just to do it again because of a POS aftermarket bearing?
I will ONLY use Toyota Original bearings from now on. It has been 80,000 miles since my new Centerforce clutch and Toyota bearings and everything is working great. I also replaced the fork and spring out of sheer paranoia. Even got the "winter" spring for the fork that was listed in the manual.
There are places you skimp and places you don't. Someplace that takes a lot of labor and time to get to is no place to save 3 or 4 bucks...not to mention what the cheap part will take out when it goes.
Old Feb 3, 2008 | 07:38 AM
  #27
dirtoyboy's Avatar
Im pretty sure those are stock SECO/AISIN clutches......
x2 on using only toyota bearings for the job....they arent that much more expensive
Koyo for the throwout and NSK for the pilot bearing
Old Feb 3, 2008 | 09:14 AM
  #28
nate9207's Avatar
yeah sounds good to me then... i'll prolly hit the yoter dealership up for a pilot bearing then. theres one only 8 miles from my house hehehe
Old Feb 3, 2008 | 12:01 PM
  #29
dlbrunner's Avatar
One big issue with clutches is heat. After a long day (6 hours) of working a clutch on the trail, I noticed fade with the stock unit. I am hoping the marlin unit I bought will help this issue.
Old Feb 13, 2008 | 08:17 AM
  #30
dirtoyboy's Avatar
I have a dual friction and it works great..ON and OFF road.....
I like how it engages firmly unlike the stocker....its not as hard to drive as some of these guys make it out to be
kawazx636
Oct 6, 2021 03:03 PM
primordialbeast117
Dec 19, 2015 12:23 PM
smilen724
13
Nov 8, 2015 04:11 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
