can someone explain the add thing to me?
Old Apr 10, 2004 | 03:30 PM
wimpywade94's Avatar
ok, now i found 2 axle from a junkyard a few minutes ago, not sure if i have add. what is that? and how do i know if i have it?
the truck is a 98 limited with 3.4l auto hubs, standard tranny,
thanks
wade
Old Apr 10, 2004 | 04:19 PM
you have add
Old Apr 10, 2004 | 04:26 PM
shazaam's Avatar
I thought he never paid attention b/c he just didn't care
Old Apr 10, 2004 | 04:38 PM
superjoe83's Avatar
Thats great
Old Apr 10, 2004 | 05:35 PM
Waterboy's Avatar
Automatic Disconnecting Diff. If you have auto hubs you have ADD. Manual hubs have a dial on each of the front wheels.
Old Apr 11, 2004 | 11:42 AM
sweet. thanks guys.
i mean thanks waterboy!
laterz
wade
Old Apr 11, 2004 | 05:07 PM
4Crawler's Avatar
This page explains ADD in detail:
http://www.off-road.com/toyota/tech/add/index.htm
Old Apr 11, 2004 | 05:18 PM
Shane's Avatar
Auto hubs != ADD
Auto hubs are an entirely different beast, and they suck. If you have ADD you have drive plates instead of lockout hubs. Auto hubs look like regular hubs, except they don't have the turnable dial and they operate by locking up if the shaft is turned forwards. They suck because they can unlock when backing up.
Old Apr 11, 2004 | 08:42 PM
toy283's Avatar
I was hoping someone would note that.
Old Apr 11, 2004 | 11:09 PM
so what would it take to switch to manual hubs right now if i wanted to? could i go to a junkyard, get a set of hubs, the axle that i need(the cv that is broken right now) and just switch the parts out, or do i need to switch both axles alltogether? or is it even feasible or needed for a truck with 3" of suspension lift on 33's?
thanks
wade
Old Apr 11, 2004 | 11:28 PM
superjoe83's Avatar
Smile
if you go to a junkyard this is what you will need:
both halfshafts off of a manual hub taco
both knuckle assemblies with hubs off of same truck
rig your add diff to be engaged all of the time
i think thats about it, im pretty sure that the inner tripod joint splines are the same so you can use your add diff with the non add axles
if im not correct, anyone please correct me
Old Apr 11, 2004 | 11:49 PM
sounds like more cashola then i was gonna spend originally.
may stick the add hubs out for a while at least for now.
thanks
wade
Old Apr 22, 2004 | 07:02 AM
NCSU-4runner's Avatar
this thread is the exact reason i was glad i had a 2nd gen IFS. manual hubs are easy then. Of course none of that matters if you JUST hang a solid front axle under there
Old Apr 22, 2004 | 07:27 AM
GRNTACO's Avatar
Auto hubs and ADD are different.
EDIT: This was covered................I'm slow
80Truck
Oct 12, 2025 07:25 PM
edoyle12
11
Mar 20, 2017 02:26 AM
dumpster84
Apr 30, 2016 06:03 AM
TDonkey
Jul 26, 2015 10:14 AM
Steven.m.paulk
Jul 24, 2015 01:44 PM
