can i shorten my own d shaft?
Old Aug 25, 2008 | 07:39 AM
cherokeechief79's Avatar
i had a d shaft lenghtened after my sas but i changed the springs to something a little lower in the front this past weekend.now i need about 1.5 inches taken out of this shaft.can i do this myself?i have acess to a machine shop and a welder but i donmt think i can fit the shaft tube in our lathe.
Old Aug 25, 2008 | 07:49 AM
DeathCougar's Avatar
You will need to machine off the weld, then shorten the tube, and reweld the assy.
If you have never done it before, just take it to a shop. Its pretty cheap insurance not to break it on the trail.
Old Aug 25, 2008 | 08:04 AM
if i cut the tube to the length i need then i can chuck it on the splined end and machine it off.
Old Aug 25, 2008 | 08:09 AM
Just make sure the cut is exactly straight, otherwise your driveline will wobble. You also need to find a way to balance the shaft, so you don't have vibration issues.
Old Aug 25, 2008 | 10:33 AM
i posted this at lunchtime and now its breaktime at work.ive already got it done.i dont know how straight it is but it pressed in tight so im assuming its good.its a front shaft anyways
Old Aug 25, 2008 | 10:58 AM
tc's Avatar
tc
I would have recommended you just cut off the splines so it will compress further.
Old Aug 26, 2008 | 07:43 AM
ok i knew this all went together too easy.
i just put the slipyoke on and tried to align it(phasing i think its called)i cant get it perfectly lined up with the fixed yoke at the other end.its very close.is this gonna give me problems?i guess i should have put the slipyoke on the splined end and then pressed it together.
kawazx636
Oct 6, 2021 03:03 PM
hiluxinargentina
Sep 30, 2015 11:12 PM
hiluxinargentina
Sep 30, 2015 05:51 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
