A/c to onboard air question.
Old Oct 16, 2005 | 02:30 PM
wimpywade94's Avatar
Hello, just wondering if anyone could tell me how excactly to attach a quick disconnect hose onto an air compressor.
or lead me in the direction of a website to tell me how to do it,
thanks
wade
Old Oct 16, 2005 | 02:49 PM
gummi's Avatar
What are you trying to do ?
I have A/C air, connected to a tank and a sensor for turning off the compressor when it's full.
Old Oct 16, 2005 | 03:11 PM
4Crawler's Avatar
Just get one of these and attach it to your air system, to the tank, to the end of a hose, etc.:
More info: http://www.4crawler.com/4x4/ForSale/4air.shtml#Chucks
Old Oct 16, 2005 | 03:23 PM
gummi's Avatar
I would..
... get a tank and connect the AC to the tank.. then lead a hose from the tank and have the quick disconnect there..
less chance of blowing a hose, more air when you need it etc..
Old Oct 16, 2005 | 03:35 PM
how should i go about connecting the ac to the tank though.
wade
Old Oct 16, 2005 | 03:42 PM
gummi's Avatar
just a hose that can handle the pressure..
... and you need to find a good tank / cylinder.
On mine the AC sucks air from the air cleaner box, then on the out air hose it's connected to a air / oil seperator, and a thin hose cycles the oil back to the intake for the AC. Afther that you can do whatever you want, I would route the air to the tank. Then from the tank I would run a hose to a sensor, that will cut the power for the AC off at 100psi. then you can have a other hoses connected to that for whatever you'd like to do with the air.. I use it for both the locker and a quick connect mounted on the rear of the truck for pumping the tires.
Old Oct 16, 2005 | 05:30 PM
4Crawler's Avatar
wade
Get one of these kits:
http://www.frontrangeoffroadfab.com/manifold.htm
MO transplant
Apr 23, 2023 11:58 AM
mussy01
Dec 13, 2016 08:20 PM
viesail
Aug 17, 2015 08:39 PM
Tacoma1313
Aug 17, 2015 05:44 PM
94ofCanada
Aug 14, 2015 06:37 AM
