BJs and shackles
Old May 4, 2005 | 05:42 AM
StKwhT_Pkp's Avatar
Question BJs and shackles
I've been looking at this stuff and I'm thinkin about it pretty hard but i want some input from you guys. I was looking at getting some ball joint spacers and some rear downey springs for my 94 pickup. This should allow me to clear 33's right? Also, would I need any other hardware with this setup? Thanks in advance.
Old May 4, 2005 | 07:11 AM
4Crawler's Avatar
Depending on the tire width and the wheel width and offset, you may be able to fit the tires with just that lift, or you may need a little extra:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Old May 5, 2005 | 04:21 AM
StKwhT_Pkp's Avatar
Hey thanks for the link. Im thinking if I get the 3" Downey springs and the spacers that I would not need a block lift. I'm sure a lot of poeple are running a similar setup so I'll keep searching the sites
Old May 5, 2005 | 09:07 AM
mt_goat's Avatar
Like Roger said, it all depends on the wheel/tire width & offset. I had rubbing with 33's even after a 4-inch lift.
Old May 5, 2005 | 09:26 AM
4Crawler's Avatar
Yes, a guy in my club had a 4" SuperLift kit on his '92 pickup, 33x12.50s on 3.5" b/s 8" rims and he rubbed, had to add a body lift to clear the tires (2"). With some/all of the 4" lift kits, you need to run a wheel with around 3.5" backspacing (to clear the lift components) and then if you also go to a wider wheel and wider tire, you end up with a much wider stance. But that increases the size of the arc that the tire sweeps while steering and the more likelyhood of rubbing. Another guy in the club has a '94 pickup, 4.75" backspaced rims, 1" body lift and torsion bar crank/1" lift shackles and he clears 33s:
More info:
Old May 6, 2005 | 06:37 AM
StKwhT_Pkp's Avatar
Thanks guys. I was looking for some 33x10.5's the other day. I guess if I'm rubbing a lot I can just get some wheels with more backspacing. Thanks again for the info.
Old May 6, 2005 | 07:23 PM
Marc P's Avatar
I went with the 33x10.5's an couldn't be happier--no rubbing and better gas mileage on the freeway with the 4.88s.
Big Little Bear
230
Nov 13, 2023 11:42 AM
Redeth005
Jun 28, 2018 08:16 PM
Scottcrb
Mar 3, 2016 11:57 AM
oldblue
Sep 28, 2015 04:07 PM
sonorn67
Sep 19, 2015 05:39 PM
