BJs and shackles
I've been looking at this stuff and I'm thinkin about it pretty hard but i want some input from you guys. I was looking at getting some ball joint spacers and some rear downey springs for my 94 pickup. This should allow me to clear 33's right? Also, would I need any other hardware with this setup? Thanks in advance.
Depending on the tire width and the wheel width and offset, you may be able to fit the tires with just that lift, or you may need a little extra:
http://www.4crawler.com/4x4/ForSale/...it.shtml#FAQ10
Hey thanks for the link. Im thinking if I get the 3" Downey springs and the spacers that I would not need a block lift. I'm sure a lot of poeple are running a similar setup so I'll keep searching the sites
Originally Posted by mt_goat
Like Roger said, it all depends on the wheel/tire width & offset. I had rubbing with 33's even after a 4-inch lift.
More info:
Big Little Bear
230
Nov 13, 2023 11:42 AM
sonorn67
Sep 19, 2015 05:39 PM
