BJ spacer fitment
Old Dec 3, 2005 | 04:17 PM
celica's Avatar
BJ spacer fitment
OK I did a search but can't find what I am exactly looking for. I am in the process of installing the ball joint spacers. They almost slide in but are a little too big. The install instructions say to grind down the back of the A-Arm. Has everybody done this or are there atlernatives to gringing it down. Doe grinding the back effect the strength of the arm? If grinding down the back is the only way to go then how much did you grind off?
Let me know as my truck is in the air and I need to finish it son so I can drive it. Thanks in advance guys.
Old Dec 3, 2005 | 04:47 PM
tc's Avatar
tc
roger is the man
http://www.4crawler.com/4x4/ForSale/...er_HowTo.shtml
Old Dec 3, 2005 | 04:59 PM
celica's Avatar
those are the install instructions but was wonderinf if anyone has had any other experiances?
Old Dec 3, 2005 | 07:07 PM
Strap22's Avatar
Sponsoring Vendor
Try this thread.........
https://www.yotatech.com/forums/show...96&postcount=1
Old Dec 3, 2005 | 08:19 PM
mike_d's Avatar
in this thread: https://www.yotatech.com/forums/f31/bj-spacers-installed-68997/ i have pictures of the installed spacer. the griding of the a-arm is so small that it really doesn't matter - it won't affect the strength at all. it's just a little bit so the spacer can be fit in there.
kawazx636
Oct 6, 2021 03:03 PM
4x4YOTA
Aug 23, 2016 09:08 AM
89YodaRunner
Sep 30, 2015 02:18 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
