Ball Joint Spacers?!?!
Old Jan 10, 2014 | 08:32 PM
ToyMachine11's Avatar
First post So ive got a 1993 pickup v6 5 speed. Id like some kinda small lift to fit 32's. Currently running 30's. gearing is 4.56.
So im thinking 2.5" ball joint spacers on the front and 3" lift blocks on the rear leafs. Trucks mainly for road us and the odd logging road/super light trail. Or would I be better to go with a body lift 3" or so??? Help me out haha. Im new to Toyotas, this is my first pickup. Loving it so far!!
The spacers/blocks seems to be a real good budget set up!
Thanks!
Old Jan 10, 2014 | 08:57 PM
Black_1985_SR5's Avatar
all you need to have to clear 32's is a hammer
Old Jan 11, 2014 | 03:03 AM
FourwheelinVT's Avatar
A 2" bodylift would be plenty, but will not improve the suspension any. I went with 1.5" balljoint spacers up front and 6" marlin shackles in back for more flex. Longer shocks can help even more but are not needed. I have a 2" body lift also and can fit 33-35" tires
Old Jan 11, 2014 | 05:11 AM
donomite49's Avatar
I've had 32's on my stock second gen pu.
Old Jan 11, 2014 | 07:21 AM
Toyota~Boy's Avatar
1.5" BJ spacer
2" block
That will clear a 33" tire that's mounted on a 8" wheel. You may have slight rub depending on your back spacing.
Old Jan 11, 2014 | 11:46 AM
ive always just pulled the front mud flaps off and hammered the pinch welds to clear 32in TSLs
Old Jan 11, 2014 | 12:22 PM
Roark's Avatar
32x9.5s fit on my truck with no modifications. Your set up would be overkill for even 33s.
Old Jan 11, 2014 | 02:30 PM
Hmmm alright. Ya I was thinking 32/10.5/15. Maybe even 33. Just thought it might have a better look with the small lift?
Old Jan 11, 2014 | 03:16 PM
skoti89's Avatar
I clear 33's with 1.5 body lift and 1.5 ball joint spacers and what is called ZUK mod in the rear. I would not recommend going over 2'' body lift. Not worth it. Stretches stuff a little too much IMO. Also, I had 3'' body lift on when I rear ended a Chevy half ton doing only about 10mph in the snow, shoved the whole body back a little bit and the front clip pushed back a couple inches. Wish I had pics to explain, but I ended up winching it back and some of the body/frame mounts did line up with out a BFH. I cut the 3'' blocks in half and put them on instead.
Old Jan 14, 2014 | 10:35 PM
Littleblue1989's Avatar
I have spacers on my truck worked great, could get 33's in it if I did some hammering inside the fenders. But to do that need cash $$$$. Good luck
Old Jan 15, 2014 | 05:57 AM
dswag's Avatar
Mine fit 33's nicely sitting on stock suspension, but my fenders are also cut a little bit.
87 4runner 22re 5speed *traded*
93 xtra-cab 22re 5speed
Old Jan 15, 2014 | 08:19 AM
Thanks for all the info so far everyone!!
Old Jan 15, 2014 | 08:34 AM
MaK92-4RnR's Avatar
I'd rather have 33x10.50s than 32x11.5s. both fit stock height.
Old Jan 15, 2014 | 11:39 AM
rattlewagon's Avatar
Old Apr 4, 2014 | 12:40 AM
beefyjw's Avatar
Ball Joint vs. Torsion Bars vs. CV Joints
I'm on a '90 XCab V6 with 33x12.5 locked front and rear. The current suspension is a 1.5" block in rear and cranked torsion bars in front. I would love a little more flex front and back without an SAS or starting to break CV joints. I've busted axle shafts, hubs, steering, etc but only one CV and like keeping it that way.
Thinking about 1.5 ball joints in front and lowering torsion a bit to get a little more flex. Wondering about angles on CV joints.
Also thinking about 6" shackles in rear with the stock springs and removing blocks.
Any thoughts? Is this worth it, or basically same ˟˟˟˟? Thanks!
Old Apr 7, 2014 | 05:06 PM
kornhuskerwizard's Avatar
I have 1.5 bj spacers and clear 33s with stock toy flappers.i would never install 2.5s.
Old Apr 10, 2014 | 07:48 PM
Berksmash's Avatar
I've been wanting to put 33's on mine but I just don't have the money for it right now
kawazx636
Oct 6, 2021 03:03 PM
ladybugRC
458
Aug 21, 2020 10:41 AM
4x4YOTA
Aug 23, 2016 09:08 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
crash813
Sep 27, 2015 07:15 AM
