Arp knuckle studs or 5th stud mod?
Old Oct 12, 2010 | 07:35 PM
SpecialScottie's Avatar
So this past weekend I headed for the desert and happened to break all 4 of my passenger knuckle studs hitting a washout. Would I be better off getting the ARP stuf kit or getting stock replacement studs and doing the 5th stud mod?
Old Oct 12, 2010 | 08:09 PM
dropzone's Avatar
Fossilized
do both, I am running ARP studs on mine but would like to upgrade to six shooters but i need to $250 on my truck in a few other places first..a buddy of mine has done several 5th studs mods so I will probably end up using my ARP's with a 5th stud
Old Oct 12, 2010 | 10:04 PM
DeathCougar's Avatar
Interesting discussion going on over at NW-wheelers as well with lots of info
I am going to be going ARP studs, and thats it. A buddy I wheel with has only ARP studs and a 302 and doesn't break anything. The key, I am finding, is to check torque before every run and make sure everything is tight. The cause of most of the failures seems to be loose nuts.
Old Oct 12, 2010 | 10:51 PM
camo31_10.50's Avatar
how about....ARP studs....and the 5th stud mod????
or get the six shooters!
that pic makes my stomach turn...
Old Oct 13, 2010 | 04:30 AM
waskillywabbit's Avatar
Knuckle studs break from improper torque, loose or too tight. Check before and after each trip.
Upgrade to chromoly studs and go from there.
:wabbit2:
Old Oct 14, 2010 | 02:28 PM
clf4i's Avatar
Just throwing this out there, trail gears 6 shooter kit is on sale right now til the end of november I believe.
Old Oct 14, 2010 | 02:36 PM
Just picked up a set of ARP studs from WabFab should be here soon, and I'll be checking the truck after every run
Old Oct 21, 2010 | 01:50 PM
Volcom's Avatar
Both. I upgraded to ARP's 2 years ago and still have had issues with them loosening up and striping the knuckles. DIRTCO has done both and has never had an issue with them loosening. I bought the Longfield 5th studs and plan on installing them sometime this week!
ladybugRC
458
Aug 21, 2020 10:41 AM
TheBFA
Feb 15, 2020 06:55 AM
Rickstwowheels
Sep 29, 2015 02:23 PM
oldblue
Sep 28, 2015 04:07 PM
Odin
Sep 26, 2015 06:56 PM
