Arp knuckle studs or 5th stud mod?
So this past weekend I headed for the desert and happened to break all 4 of my passenger knuckle studs hitting a washout. Would I be better off getting the ARP stuf kit or getting stock replacement studs and doing the 5th stud mod?:wrench:
http://i372.photobucket.com/albums/o..._6126352_n.jpg |
do both, I am running ARP studs on mine but would like to upgrade to six shooters but i need to $250 on my truck in a few other places first..a buddy of mine has done several 5th studs mods so I will probably end up using my ARP's with a 5th stud
Interesting discussion going on over at NW-wheelers as well with lots of info
I am going to be going ARP studs, and thats it. A buddy I wheel with has only ARP studs and a 302 and doesn't break anything. The key, I am finding, is to check torque before every run and make sure everything is tight. The cause of most of the failures seems to be loose nuts. |
how about....ARP studs....and the 5th stud mod????
or get the six shooters! that pic makes my stomach turn...:( |
Knuckle studs break from improper torque, loose or too tight. Check before and after each trip.
Upgrade to chromoly studs and go from there. :wabbit2: |
Just throwing this out there, trail gears 6 shooter kit is on sale right now til the end of november I believe.
Just picked up a set of ARP studs from WabFab should be here soon, and I'll be checking the truck after every run
Both. I upgraded to ARP's 2 years ago and still have had issues with them loosening up and striping the knuckles. DIRTCO has done both and has never had an issue with them loosening. I bought the Longfield 5th studs and plan on installing them sometime this week!
