a-arm rubbing issues - solution came in the mail today
Old Oct 11, 2005 | 05:45 PM
BruceTS's Avatar
Originally Posted by francr
apologize for the hijack. WIth the uniball like camburg engineering upper arm installed, can you still align the front end to stock limits?
The simple answer is YES
Old Oct 12, 2005 | 04:32 AM
jacksonpt's Avatar
Senior Member
Not to sidetrack from the spacers thing... but I have a couple of questions about the initial a-arm issue.
You said you were concerned when you aired down... that doesn't really change things, does it... as the buldge form airing down is at the bottom, where all the pressure/weight is, right?
Also... the first pic looks troublesome... the second pic looks fine. Back when I had my stock a-arms and 32/11.5-15s, I could juuuuust barely squeeze 1 finger between the a-arm and the tire. I ran/wheeled those tires for almost 50k miles with no problems. When the suspension travels, the a-arm moves with the tire, so the distance between the tire and the a-arm should never change, right?
Am I missing something here?
Old Oct 12, 2005 | 09:32 AM
AznSky's Avatar
punkbek - Sorry I don't have the spacers, sold them a long time ago
jackson - I started thinking about that recently as well. From what I gathered talking to a few tire engineers, the conclusion is that when you do air down, you are actually safer. Reason being is that when you air down, the bulge will be more at the bottom, and the top section width will barely increase by 1 mm if that. This is because the inflation pressure is not great enough to keep the cords stretched and round, and normally the top half of the tire is in more tension than the bottom, so the lesser tension at the bottom of the tire will allow it to bulge out more so you start getting material compression at the bottom. And the top half doesn't bulge out more because the cords are still in higher tension.
As for the a-arm issue, in our case, the a-arm actually moves inward when you droop the tire, this I noticed when they were installing my 285's. At full droop the tire was rubbing against the a-arm, but once we set the vehicle down it didn't touch (but was VERY close). I'm still trying to understand completely why, I started thinking about the upper and lower a-arm acting as a 4-link with the vehicle but then it shouldn't go inward if it moves in any direction from horizontal.
Either way, that's what I noticed about the a-arm. I'll look into it more.
btw first pic and second pic are the same side. Just from different angles.
Old Oct 15, 2005 | 01:19 PM
BruceTS's Avatar
With the stock balljoint, the upper a-Arm moves closer to the tire the further it droops, because of where the pivot point is located, unlike the Uniball design that stays virtually the same distance from the tire all the time.
Old Oct 16, 2005 | 10:18 AM
  #25
ZUK's Avatar
ZUK
Rob---the rubbing issue goes away with narrower tires....don't know what size you have (33x12.50? ) but my 33x10.50's have plenty of gap and no wheel-wellrubbing on the turning scrub radius. I have the factory cool aluminum 7" wide rims on my 87 Runner. By not using wheel spacers, the lower BJ will live a long time too. ZUK
lledwod
Aug 30, 2016 01:03 PM
nonstop
Jul 24, 2015 06:29 PM
ddg71
Jul 24, 2015 01:24 PM
Nailit69
Diesel Swaps
Jul 21, 2015 05:28 PM
MTLroadierunner
Jul 6, 2015 12:17 PM
