ARB compressor mounting
Old Nov 6, 2009 | 11:31 AM
muddpigg's Avatar
I've got an ARB to instal, planning on putting it in the rear axle. The instructions say for a single ARB locker mount the compressor within 4' of the locker, its the compact compressor so won't air tires with it. Where have you guys mounted your compressor? Any one had issues mounting compressor more than 4' from the locker?
Old Nov 6, 2009 | 06:18 PM
tc's Avatar
tc
I think it would be better to keep the wire to it short - even the compact one pulls a fair amount of juice. One thing to keep in mind FOR SURE is that the intake will be protected from water.
Old Nov 6, 2009 | 06:26 PM
grant526's Avatar
Like TC stated, it's probably better to keep the power lead as short as possible.
It may take it just a fraction of a second longer to actuate, but I would think that a longer lead hose from the compressor to the Diff would create a "larger reservoir" of air to keep the unit engaged.
Personally, I'm planning on installing an air tank to go with an ARB, when I finally get to that point. That way the compressor only has to keep the tank pressurized and not keep kicking on and off. . .
Good Luck with it!
Post up where you end up putting it and your build info
Old Nov 6, 2009 | 08:20 PM
dark_fairytales's Avatar
its not an arb compressor but it works out great.
Old Nov 7, 2009 | 01:36 AM
muddpigg's Avatar
DF: I've got my ignition box in that location. Just enough space between the ignition box and the carbon canister to sqeeze the compressor in but I'm concerned with temperature of the two so close together.
Old Nov 7, 2009 | 06:28 AM
Tofer's Avatar
Sponsor
I mounted my compressor on the rear driverside wheelwell inside the truck. No issue with wiring and used the supplied wiring harness.
Old Nov 7, 2009 | 10:53 AM
ya i dont really have a heat issue there due to only needing to run the compressor for 15min once in the whole day to fill the tank. Any way the compressor dose not seem to heat up the surrounding area but your compressor is different
Old Nov 7, 2009 | 12:05 PM
muddpigg's Avatar
Thanks DF will give it look see, whenever I get off my duff and go turn some wrenches.
Old Nov 14, 2009 | 08:36 AM
Tragic Drive's Avatar
If you can get your pneumatics leak free it shouldn't have to cycle.
Mine does have some leaks so it runs for about 3 secs every 15 minutes.
It leaks from the top of the pressure switch when I sprayed it with soapy water that's where the bubbles formed.
[IMG][/IMG]
Old Nov 14, 2009 | 05:21 PM
muddpigg's Avatar
How loud are these little compressors?
Old Nov 14, 2009 | 06:07 PM
GenXr's Avatar
loud enough you'll hear it when it kicks in. That's for sure but it's cool to hear.
Old Nov 14, 2009 | 07:37 PM
muddpigg's Avatar
Toying with the idea of mounting it inside.
Tofer are you talking about mounting in the stock jack location? That's where I'm leaning towards.
Old Nov 15, 2009 | 11:04 AM
cadman's Avatar
I mounted mine on a sheet of Delrin and used silicone rubber bumpers for vibration management and hold it in place:
Installed in the driver side storage compartment. Since it's not permanently installed it only takes a few minutes to take it out and put it back in.
I left space on the filter end of the compressor in case I needed to install a pc chassis fan, but the compressor only engages the lockers so it only comes on for a few seconds. I put a locker up front since the photos, so now I've got both solenoids and lines installed and it still doesn't produce any heat to speak of.
A2theK
Sep 30, 2016 12:50 PM
justdifferentials
Just Differentials
Sep 17, 2015 06:14 PM
coffey50
Jul 28, 2015 10:55 AM
A2theK
Jul 12, 2015 10:46 AM
skoti89
Jul 8, 2015 12:05 AM
