add a leafs from a chevy?
Old Sep 6, 2009 | 01:37 PM
DRO85SR5's Avatar
hey sorry i dont know if this is the right forum for this but i got some add a leafs from this guy and i was wondering if they would work on my truck i think there for a chevy, i googled the part number (FT20024) and it popped up with a chvy but would they fit and work on my 85 pickup? and if so would it lift it all crazy...any help would help thankss...
aNDY
Old Sep 6, 2009 | 01:50 PM
4Crawler's Avatar
Measure the length and width and see how that would work with your springs. Likely they are about 1/8" wider, so might be an issue with the stock u-bolts, if you still run those. But measure and see. Also see how thick they are, there are basically 2 types of AALs, one is long and thin (these are the desirable kind) and the other are short and/or thick, these are not desirable ad they are very stiff and may cause your existing spring leaves to bend over the ends of the stiffer AAL.
Old Sep 6, 2009 | 01:54 PM
DRO85SR5's Avatar
there 2.5 inch wide but there almost as long as the factory leaf spring but there long and thin, they look like they have a good arch to them , the AAL is at my GFs house right now but are leaf AAL pretty much them same for all like universal
Old Sep 6, 2009 | 02:13 PM
4Crawler's Avatar
Well, you need to see if the width will fit and on the length, see how that works with the existing leaves, spring clamps, etc. In general, an AAL is somewhat universal, but is typically designed to fit into some existing spring pack, which determines the width, length, thickness and stiffness. If those dimensions happen to fit another spring pack, then you can probably use it.
Old Sep 6, 2009 | 02:30 PM
DRO85SR5's Avatar
alright 4crawler thanks ill check the specs out hopefully they work ill post a pic if i get them on tommorow
ktm192k
Oct 1, 2015 08:47 AM
Brodetski
Sep 30, 2015 11:50 PM
JookUpVandetti
Sep 30, 2015 08:58 AM
oldblue
Sep 28, 2015 04:07 PM
83
Sep 27, 2015 04:13 PM
