Add a Leaf/Shackles
Old May 4, 2005 | 03:24 PM
ekim121's Avatar
Add a Leaf/Shackles
I'm looking for about 2 inches of lift for the rear of my truck to match ball joint spacers and a slight t-bar crank. The truck will spend a minimal amount of time with the bed loaded and it is my daily driver. So, what would you all suggest? Thanks.
Old May 4, 2005 | 04:49 PM
4Crawler's Avatar
The Rancho Soft-Ride-AAL (http://www.gorancho.com/) are very good, 2 pair of leaves, on long/thin, one shorter/thicker that you can mix-n-match as needed for the lift and ride quality you want. Then if needed, shackles can be made to pick up the rest of the lift:
http://www.4crawler.com/4x4/ForSale/...shtml#Shackles
Old May 4, 2005 | 06:52 PM
Yamaha+Toyota=Fun's Avatar
I got some short AAL's from JC whitney. They have been in for about a week so far. They havent quite broken in yet, but the lift is about 2". They ride pretty stiff, but still flex fairly well.
Obmi
Oct 4, 2015 11:30 AM
JookUpVandetti
Sep 30, 2015 08:58 AM
Cycles
Sep 29, 2015 06:37 AM
oldblue
Sep 28, 2015 04:07 PM
ktm192k
Sep 24, 2015 03:36 PM
