AC Air Compressor
Old Jan 1, 2008 | 07:34 AM
4runnerchevy's Avatar
Banned fruitloop
AC Air Compressor
This is nothing new but : I am turning my AC compressor into an on-board air source. I have a 4.3 with a Harrison Compressor, but this should work for any AC compressor. My preliminary tests filled my 36" x 12.5" tire from 0-30 psi inside 35 seconds @ 900 rpm. Another test gave me 300 psi in a closed circuit @ 2200 rpm. I will be using a pre-oiler and a post oil seperator, pressure switch, check valve, safety valve, and my existing 5gal tank (I already have CO2 as onboard air).
If anyone is interested, I will post pics, soon as I get all the final fittings. If not interested then let the thread die.
Old Jan 1, 2008 | 07:59 AM
phildelfino's Avatar
No way, post it. This would be a cool mod for anybody to do. Right now I run this air compressor that I hook up to my battery with clips. It takes awhile and I donot mind waiting, but faster is better when it comes to some things.
Old Jan 5, 2008 | 03:27 PM
Banned fruitloop
Ac
I am figuring 5-7 CFM at 80 PSI ok. Waiting till it stops raining to finish comp. output.
Print
I will run the swith at 90 to 140 PSI.
Old Jan 5, 2008 | 03:51 PM
4Mogger's Avatar
Print
just make the discharge line as long as possible with the coalescing filter also as far as possible from the compressor to allow the air to cool a bit.
Old Jan 6, 2008 | 06:48 AM
Banned fruitloop
Heat
It doesn't seem to be an issue yet (testing) but I will keep an I on the temp.
Thanx
Old Jan 6, 2008 | 09:54 AM
Banned fruitloop
Updated Schematic
This might help with the heat.
Old Jul 16, 2008 | 02:14 PM
blueyoda's Avatar
subscribed.
Old Jan 9, 2009 | 11:03 AM
YOTA-ARMY's Avatar
I just set my compressor as on board air. but don't have an oiler so how much oil should I put in manually? and how often?
1980 hilux, 22r
Old Jan 9, 2009 | 11:24 AM
snobdds's Avatar
Post those pics once you got it. Sounds like a great idea!
mussy01
Dec 13, 2016 08:20 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
RatOmeter
Oct 22, 2015 03:17 PM
calderp
Jul 27, 2015 09:58 AM
skoti89
Jul 8, 2015 12:05 AM
