87 toyota question
Old Oct 22, 2009 | 07:49 AM
buckcreek's Avatar
87 toyota question
First of all you guys rock, love this site don't always log on but follow a lot of the posts.
Here's my question just traded for a 87 22re 5speed 4x4 truck , The previous owner installed a 3 inch body lift oin the truck, Here's the problem if in lo lock and try to go in reverse the tranny shifter knocks the transfer case shifter out of lo, Is there a way to correct this problem? Has anyone had this problem before?
Thanks
buckcreek
Old Oct 22, 2009 | 08:07 AM
TubedYota's Avatar
I never had that problem but I just read this the other day....http://www.4crawler.com/4x4/ForSale/...wShifter.shtml......cool site with a lot of good ideas......actually I think that site was how I found this place......
Old Oct 22, 2009 | 08:10 AM
dropzone's Avatar
Fossilized
extremely common with a BL.
and you are in 4 low, not lo lock.
Easiest thing to do IMO is to remove the shift boot, pop the Clip holding your TC lever in place. Pull the TC lever out, heat and bend it slightly one direction or the other to get it out of the way of your trans shifter. DO NOT attempt to bend it while the TC lever in still in, you are liable to screw up a shift fork or something.
could also be that the shifter is hitting the opening on the transmission tunnel
Roger's site (4crawler) is an awesome place to learn a ton of stuff...
Old Oct 22, 2009 | 08:55 AM
4Crawler's Avatar
A whole bunch of options below to fix that problem:
- http://www.4crawler.com/4x4/ForSale/...l#ManualTranny
Old Oct 22, 2009 | 10:33 AM
buckcreek's Avatar
Thanks for such a fast reply, I will check this out.
Old Oct 23, 2009 | 08:38 AM
buckcreek's Avatar
I am on a very tight budget and would like to go with a two stick setup for the transfer case does any one know of a write up on building one of these for my truck (homebuilt).
Old Oct 23, 2009 | 09:25 AM
4Crawler's Avatar
Lots of threads on the Pirate4x4 forums about this, some below:
- http://www.pirate4x4.com/forum/showt...ght=twin+stick
Old Oct 24, 2009 | 09:38 AM
buckcreek's Avatar
great info !
how difficult is the pin in the case to remove?
Old Oct 24, 2009 | 09:48 AM
4Crawler's Avatar
Intrinsically not that hard, but depends on how cooperative your case is:
- http://www.4x4wire.com/toyota/tech/twin_stick/
I pulled mine some years ago with the case out of the truck. I hard the biggest problem with suction holding the pin in place, finally got a little telescoping pencil magnet, ground it down to fit in the hole and gradually worked the pin out. I don't have twin sticks yet, but been running unpinned for years now with no problem. Hope to finish up my triple stick shifter (dual cases) one of these months.
bigjstang
Jun 2, 2025 03:56 PM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
Cplmike
Jul 8, 2015 08:47 PM
God's Bounty Hunter
Jul 8, 2015 12:54 PM
