87 toyo need to make 47.5 springs work on 43 in mounts !
Old Mar 27, 2009 | 08:05 PM
grizz's Avatar
87 toyo need to make 47.5 springs work on 43 in mounts ! i need help
the deal is i have a set of ome 47.5 in springs . my truck takes 43in .how can i make these work ?
Old Mar 27, 2009 | 08:13 PM
swapped89's Avatar
Order a pair of trail-gear spring hangers http://trail-gear.com/rearhangers.html , cut off old front spring hangers and mount the new spring hangers in the correct location.
Old Mar 27, 2009 | 08:14 PM
grizz's Avatar
do i move the shackl mount or do two shackls
Old Mar 27, 2009 | 08:23 PM
swapped89's Avatar
i would leave the shackles alone completely. just weld on the new hangers for the front of the springs about 3-4.5 inches forward of the old hangers. measuring from the center of the old spring hanger bolt hole, to the center of the new spring hanger bolt hole.
just tack the new spring hangers on. assemble the springs and everything set the truck down and check the shackle angle before you finish weld everything
Old Mar 27, 2009 | 08:28 PM
grizz's Avatar
whats the best shackle angle ?
Old Mar 27, 2009 | 08:35 PM
swapped89's Avatar
it depends on how much weight your puttin in the truck and whether or not yer lookin for flex or a good ride. but i bet if your truck is stock. then you could just look at the angle of the shackle as it sits right now on flat ground and just try to get it as close as possible to that with the new springs and hangers.
Old Mar 28, 2009 | 10:01 AM
grizz's Avatar
ok thanks for your help.any one else have any input .it seems to me if i move the mounts up 4 in it would chang the axle angle and the tires to far forward in the wheel well
Old Mar 28, 2009 | 11:02 AM
4Crawler's Avatar
What sort of vehicle are you asking about? All the 1st gen Toyotas had 47" long rear springs:
http://4x4spot.com/misc__spring_information.htm
Simple way to set things up. Take old springs and measure front and rear lengths (from the center pin to the center of the respective spring eye). Do the same on the new springs. Then move the front hanger forward a distance equal to the difference in the front lengths of the old and new springs. Then if all the added length is not in front, then either move the shackle hanger back or add that length to a longer spring shackle.
Old Mar 28, 2009 | 02:56 PM
grizz's Avatar
it'a a 87 pickup ex cab. what happens is when i jack the axle up to get the tire on the shackels hit the frame
Old Mar 28, 2009 | 03:02 PM
4Crawler's Avatar
Which way does the shackle swing, forward or back to hit the frame? And when you say 43" and 47.5" long springs, how are you measuring, i.e. eye to eye chord length or eye to eye along the arc of the main leaf (that is the proper way to measure)?
Old Mar 28, 2009 | 03:31 PM
grizz's Avatar
ok shakles swing back.old springs by arc length 26 3/4 r 20 1/2 f give or take.new springs 29 3/4 r 22 f . i might have the wrong springs but there made to give a small lift so ???
Old Mar 28, 2009 | 03:35 PM
4Crawler's Avatar
Sounds like you have '89 or later pickup springs and yes, they are longer:
- http://4x4spot.com/misc__spring_information.htm
Old Mar 28, 2009 | 03:36 PM
grizz's Avatar
man thanks for your input
Old Mar 28, 2009 | 03:43 PM
grizz's Avatar
ok so i have 89 + springs.thanks for the help 4crawler.so would i get more lift if i fab these up or not
Goddamnboh
3.4 Swaps
12
May 11, 2016 09:22 PM
voiddweller
19
May 2, 2016 09:10 PM
Niameyrider
Jun 25, 2015 05:50 AM
gog1968
Jun 22, 2015 05:55 AM
Bajawfo
Jun 16, 2015 07:31 PM
