54MM Socket
You might not have to order it, I got mine at monument auto if you have those around. Also, I hear the standard 2 1/8" socket works too so a hardware store or sears might have it.
Originally Posted by Hyperlite
try a screw driver or punch. hit it lightly at an angle on every side of the nut, usually works for me
The 54mm/2&1/8" socket is just one of tools you need to have.
the nut lines up with something inside that is bent over the nut to keep it from vibrating out. You can get it tight with my method, probibly not the best.
Not sure about torque, but the nut needs to line up with the washer behind it so you can bend the washer over it, if you torque it it might not line up......
This method is for solid axle (birfields), might be different for IFS
Originally Posted by PirateFins
You can check the play and free wheel rotation with a spring guage just like you are supposed to do.
Originally Posted by Shane
It's called a star washer, and you don't line up the nut to it. You torque the first nut properly to set the preload, install the star washer and torque the second nut properly. Then you fold over the appropriate ears of the star washer to hold the nuts from coming loose. If the preload is not set properly you will destroy the bearings, and it is not possible to set the preload with the hammer and chisel method.
They are identical.
They are identical.
what is t100 front hub nut torque specks and procedure
does anyone know the front hub nut torque specks and procedure for 96 t-100 4wd IFS?
This seems too be along the lines of this thread but I started a new thread see more details of my question at:
https://www.yotatech.com/forums/show...839#post464839
You should be verifying the preload by doing this (measuring it with a spring gauge) regardless of how you tighten then.
If so, where did you but it?
I have asked a couple Toyota mechanics where I could buy a sping gauge and they told me they don't use one or if they did use one once or twice, after doing it a couple times they can do by feel now and don't need it.
So, every time I have repacked my front wheel bearings or changed the rotor or something I just follow the instructions in the shop manual for setting the preload, but I have never verified it with a spring gauge
Originally Posted by fpkelly
Anyone have one in the St Louis area? Im trying to take apart the front of the IFS and the channel locks wont get the one side off and I don't have time to order one.
The only IFS part they are for is...
The nut after the lock out the holds the wheel bearings. This is only 86-95 IFS.
Since the person who asked appeared to have a Taco...
Taco's have a 35mm one. IIRC
