5" Trail Gear Springs.....Now What Shackle???
Old Jan 26, 2009 | 07:19 PM
ChickN's Avatar
Red face 5" Trail Gear Springs.....Now What Shackle???
hey guys.....ran into a problem when i put on my new 5" TG springs!!! i put on the springs, u-bolt flip...and i used the stock shackles....well now the shackles sit on the frame which means i have ZERO up travel and ride is....well, bad! so i need to know what u guys think my best option is for a shackle....im guessing a TG wide body un-braced shackle.....also i dont want any more lift which im afraid that i cant avoid that! any help would be great...thanks!!!
Old Jan 26, 2009 | 07:50 PM
4Crawler's Avatar
General rule of thumb is add an inch of shackle length for each inch of longer spring. Likely yours are 47" long, stockers are 45", so +2" shoould do the trick:
- http://www.4crawler.com/4x4/ForSale/Shackles.shtml#FAQ3
Or if you want to figure out in detail:
- http://www.4crawler.com/4x4/CheapTri...l#Applications
Old Jan 26, 2009 | 08:14 PM
BLKNBLU's Avatar
I'm in the midst of placing a TG 5" rear kit. It came with 5" shackles, but we decided to bump it up to 6" shackles. This is on top of mounting the shackle hangers up on 2 inch platforms to begin with to try to get the 5" rear equal to the 4" front. For perspective I have some pics with the 5 and 6 inch shackles here:
https://www.yotatech.com/forums/f66/...72/index6.html
So my thinking is the TG shackles might not make you that much higher but would work with the spring better.
Old Jan 26, 2009 | 09:28 PM
ChickN's Avatar
thanks guys that really helps alot....so 4crawler, you think i should go with the 5.5 inch eye to eye shackle from TG???
Old Jan 27, 2009 | 06:15 AM
4Crawler's Avatar
Measure the spring length and compare that to your old springs and see what you come up with.
Old Jan 27, 2009 | 07:31 AM
ChickN's Avatar
its about 2.25 inches longer than the last springs i had on it...here are some pics of ow it down travels but if you look close you can see that the passanger tire doesnt travel up at all!!!! also...what about a boomerang shackle???
Attached Thumbnails 5" Trail Gear Springs.....Now What Shackle???-0124091615.jpg   5" Trail Gear Springs.....Now What Shackle???-0124091547.jpg
Old Jan 27, 2009 | 07:43 AM
4Crawler's Avatar
Then a shackle about that much longer than stock is what you need. Wide body or boomerang design helps with clearance around the body mount bracket where the shackle hanger sits inside of.
XtraCab
Apr 12, 2020 05:25 AM
Scotto6591
Sep 1, 2015 03:24 PM
Backcountry411
Diesel Swaps
Jul 29, 2015 01:33 PM
msane99
Jul 27, 2015 06:14 PM
Backcountry411
Jul 24, 2015 08:06 AM
